MOD EFan
by Hpimichael02 » Mon Oct 25, 2010 10:47 pm
GuyS,
I'm attempting to do an efan conversion, but two questions, will 2 12" fans be sufficent cooling, and what belt doi use, any part number any one have?
Hpimichael02
by Hpimichael02 » Tue Oct 26, 2010 12:21 am
The belts not an issue anymore, I've searched for the efan cooling on the OS and did not locate anything :(
Hpimichael02
by TangoBravo » Tue Oct 26, 2010 3:37 am
Well come on tell us the belt your going to run? I need to know for my conversion :excited:
TangoBravo
by Zero » Tue Oct 26, 2010 5:50 am
I am lost as to why there is talk about needing a belt when you instal an Efan kit?????? the stock fan is not spun by a belt, but by a clutch assemble attached to the crank.....is it not?
by bdp1978 » Tue Oct 26, 2010 8:43 am
Agreed, not sure what youre mentioning with a belt?? The point of the electric is that they are not run by a belt therefore creating a little less drain on the engine.
It's pretty well documented that the 98-02 LS1 electric fans work very well on our vehicles.
bdp1978
by Hpimichael02 » Tue Oct 26, 2010 9:09 am
And btw my fan is fun off the belt hints why I asked about belt size not the crank only, so therefor Need different size belt to cut off the Slack of going around the fan pulley, and thanks bdp
Unless the bell housing thing stays on then I guess the factory belt would do but I don't see why that would stay :?
Hpimichael02
by The Roadie » Tue Oct 26, 2010 9:32 am
The OS has MANY discussions about Efans including my $500 failed experiment. I concluded they were not suitable for offroading the places I go. YMMV.
You will lose your water pump if you bypass the fan clutch pulley.
The crankshaft is a different pulley.
by bdp1978 » Tue Oct 26, 2010 9:54 am
I guess I am confused. We're talking about an e-fan that still runs off the belt somehow? Maybe I need a little more :coffee2: this morning.
bdp1978
by fishsticks » Tue Oct 26, 2010 10:25 am
I think the OP forgot that the fan clutch is attached to the water pump pulley... and that he still needs the water pump even if he uses e-fans. :mrgreen:
Or he could get an electric water pump...
(Not for our trucks... don't get your hopes up.)
by TangoBravo » Tue Oct 26, 2010 12:41 pm
One angle I am trying to work is an upgrade in the water pump department to include a smaller diameter pully to up the rotation of the drive shaft for the water pump. Since without needing to bolt the stock fan mount to the pully I will have room to go down in pully size. This is why I am interested as to if anyone is using any mods that use a smaller belt.
TangoBravo
by Hpimichael02 » Tue Oct 26, 2010 1:34 pm
Ya I wasn't aware that the bell housing controlled somthingvelse as well as the fan coming through from the shaft, I'm used to pre 95' hondas and toyotas lol with only 3-4 pulleys
Hpimichael02
by g wallace » Tue Nov 27, 2012 12:10 am
Hey guys if you get rid of the fan and clutch assembly you're going to turn your computer check engine light on the clutch on the fan is control from the computer on the car if you unplug it it will switching into limp mode in you'll see what I'm talking about
g wallace
by djthumper » Tue Nov 27, 2012 1:40 am
Greg,
It appears you have struck out 3 times today on your postings... Please read through the forums and you will find out most of this stuff has already been answered. You might want to post an intro as well.
Return to Electrical / Radios
