Driving and Fog Lights + Quadbeam Mod
by Jon A » Sat Nov 27, 2010 6:52 pm
I used the diode mod from that other site for the quadbeams. Added to that were Hella Micro DE fog lights and KC 5" Round 100 Watt driving lights (KC 1485). The KC's came with the Kennesaw bumper--they're available in fog, flood, driving or long range beam patterns; I opted for the driving. Here are the results:
Stock low beams:
Hella Fogs added:
Stock high beams added (remember without the quad mod the above two would shut off when the highs are switched on):
KC Driving lights added:
Same progression as above:
This is easily one of my favorite mods; well worth the cost and the effort. The Hella fogs do a great job of lighting up the sides of the road and lighting up the ground in front of you when offroad and the KC's add considerable range over the stock brights.
I will probably add more in the future but this combo does a pretty good job of providing a very good baseline without having to add lights on the roof (which must be covered, can't be used on the highway) or the bumper where they'll block the radiator and be vulnerable to impacts. I'll probably do others in the future but it's nice to not have to rely on them.
Jon A
by DmccartneyFF2TB » Sat Nov 27, 2010 6:58 pm
Dude ur TB is nasty stright up.
Dame
BDS,ROUGH COUNTRY,
Smitty Build XR-C8 Winch
www.wm4x4.com
DmccartneyFF2TB
by fishsticks » Sat Nov 27, 2010 8:45 pm
FWIW I'm in Washington too and have never been hassled about my uncovered roof lights.
by Jon A » Sun Nov 28, 2010 3:37 am
DmccartneyFF2TB wrote:Dude ur TB is nasty stright up.
Thanks.
fishsticks wrote:FWIW I'm in Washington too and have never been hassled about my uncovered roof lights.
Thanks, that's good to know.
Jon A
by SteveTB03 » Sun Nov 28, 2010 5:06 am
You understood what Dm said??? I couldn't one bit.
Go Big & Go Broke
SteveTB03
by bartonmd » Sun Nov 28, 2010 12:04 pm
SteveTB03 wrote:You understood what Dm said??? I couldn't one bit.
My freshman year at college, there was a girl that I had a couple classes with... She was also from MA (Boston)... She kept asking me if I wanted to go to a "potty"... My response was always "Why would we go to the restroom and screw? We can do that in my dorm room!" We got a kick out of it...
by themightysteveo » Mon Nov 29, 2010 3:49 am
Very nicely done! I like it! Very inspiring :cheers:
themightysteveo
by kodachrome9319 » Tue Nov 30, 2010 8:17 pm
AWESOME. I think I've found some more inspiration!
kodachrome9319
by TangoBravo » Wed Dec 01, 2010 12:05 am
kodachrome9319 wrote:AWESOME. I think I've found some more inspiration!
Hey if your interested we could do that diode mod when you come by to do the plugs, I have wanted to do that mod for abit and after seeing how much it helps at night I am doing it for sure, could do both TB's. I think the diode is like 2 bucks at radioshack.
TangoBravo
by kodachrome9319 » Wed Dec 01, 2010 12:47 am
I'm going to try to buy new fog light bulbs and might even break down and buy Silverstars for the headlights, yeah, we can do that. I'll hit you up on BBM after the Guppies game.
kodachrome9319
by TangoBravo » Wed Dec 01, 2010 5:58 pm
Hey if your interested we could do that diode mod when you come by to do the plugs, I have wanted to do that mod for abit and after seeing how much it helps at night I am doing it for sure, could do both TB's. I think the diode is like 2 bucks at radioshack.[/quote]
I'm going to try to buy new fog light bulbs and might even break down and buy Silverstars for the headlights, yeah, we can do that. I'll hit you up on BBM after the Guppies game.[/quote]
Back when I had big bucks to spend I got the most expensive Silverstars you can buy for our TB both high and low beams, man are they worth the money. IMO night and day and with the quad light mod you shouldn't have any problem seeing anything.
TangoBravo
by madmanvillain » Tue Apr 05, 2011 6:11 pm
What is the diode mod that you used? Im doing my lights in the next couple weeks and looking at a couple options for the quad beam. thanks
madmanvillain
by dirty anton » Tue Apr 05, 2011 10:23 pm
there are a few ways to choose from, the os talks about them to. this is the cheapest mod
we will ever do at like 2 dollars or so. anyway the way i did it is: part #276-1104
and its two rectifier diodes (in4005)at radio shack.go to fuse panel under rear seat.take off cover for fuses.
you will see 2 harnesses on the side of panel,an upper and lower.find the green an white wire slot on the upper harness.
then insert the anode side(or black side) into this slot. the other end the cathode side(or silver stripe side)twists together with your other diodes cathode side.
(i soldered them) and plug this into the black and white wire slot on the lower harness. now plug the anode side(or black side) into the pink and white wire slot on the lower harness. i know it sounds a little confusing :scratch: but once you start with everything in hand its really easy. i had to fold the wire ends on the diodes that were pushed in the slots to have a better connection,you will see what i mean. no cutting of wires was needed.however you could always skin a little off the wires and solder.takes seconds to reverse this if needed.
now when you hit your high beams your lows stay on and fogs stay on.check your laws, some states are more strict than others with 6 lights runnin. haha to make matters worse i have my 2 bumper mounted kc lights relayed off the hi beam sw also! talkin bout light! :twisted: you will have fun with this.
dirty anton
by lil_freak_66 » Fri Apr 29, 2011 12:43 pm
i know what im adding in when i rewire everything! (adding in a wig wag to hi beam and bumper lights,wiring the bumper lights to come on automatically with hi beams,cb radio's to be powered only when vehicle is turned on)
Michigan Search & Rescue.
SARTECH III
lil_freak_66
by navigator » Fri Apr 29, 2011 3:46 pm
Anton, I see you used two diodes but others only used one, am I missing something?
by dirty anton » Sat Apr 30, 2011 12:42 am
one diode allows the low beams to stay on when you hit the high beams on. normally the fogs would go off whenever the highs are activated. but with the second diode your fogs will stay on with high beams. not sure if you can get all 6 lights on with just one diode. there are other ways to do this but are more complex. the 2 diode method seemed the easiest and most practical.
dirty anton
by navigator » Sat Apr 30, 2011 7:17 am
Thanks Anton, I don't have fogs yet so I could do with one diode for now.
by Blackout » Sat Apr 30, 2011 10:49 am
You don't have the stock fog lights in the bumper?
Blackout
by navigator » Sat Apr 30, 2011 3:47 pm
nope, I have an LS.
by bgwolfpack » Sat Apr 30, 2011 4:40 pm
navigator wrote:nope, I have an LS.
Return to Electrical / Radios
