MASS'14978.x 78-88 GM Metric G Body
MASS'15010.x 64-72 GM A Body
Find them both Here
Cost is just $135.17, and still just $5 shipping to the lower 48.
Full description here:
Stock lower control arms on that muscle car of yours are of an extremely flimsy stamped sheet metal construction. Soggy rubber bushings complete the recipe for unwanted wheel hop, deflection and flex.
Massive has created a stronger solution. Huge 1.5” heavy wall steel tubing can harness even the highest HP load with ease. Durable and stable polyurethane bushings transfer your hard earned torque where it belongs – the pavement. Fully TiG welded. Premium thickness powder coating with a prominent Massive logo so people know your using the best.
Includes Massive's HARDCORE HARDWARE kit. Only the finest Yellow Zinc 170,000 PSI Grade 8 bolts with Nylock nuts and washers. Strong enough for all power levels and replaces your weak, rusted stock stuff.
As usual, these arms aremade in house here in the USA – so you know the quality is as good as it gets.
Get ready to rock your 60 foot times!!!
