SHURflo Aqua King Mini 1.0 12v pump, 1.0 GPM, self-priming, run dry, automatic 30 PSI switch. $55
.jpg)
SHURflo Twist-on Strainer 1/2"
1/2" ID Reinforced Clear PVC tube for inlet, 1/4" ID Reinforced Clear PVC tube for outlet, with fittings.
Liquid Dispenser Tap
No tank yet, but I'm looking at a special order from plastic-mart.com for about $120. I'll also need to pick up the wiring and a toggle switch to turn the pump off when not in use. I'm guessing the entire project will run about $250 with all the hardware for mounting. I'm hoping the plastic beer dispenser is able to hold up to the PSI of the pump. It should, as there are some beers/kegs that run in the 20-30 PSI range.
