by Trail X » Fri Jun 23, 2017 9:20 am
I wouldn't recommend messing with the C clip. That's what retains your CV axle into the disconnect. If its isn't to spec, it could mean that your retention force isn't high enough.
My trick is to apply antiseize or grease to the splines of the CV shaft, get it into place, then use the plunging motion of the tripod joint to hammer it into place. Grab the driveshaft of the cv axle, and use it as a slide hammer. DO NOT use a hammer on the outside end of the CV shaft, as it will try to transmit the load through the CV joint, which is not made for loading in that direction.
