offroadTB.com • View topic - DIY Front differential lock (?)
by stastyle » Wed Nov 30, 2016 7:52 pm
Hey guys!
I just had an idea (which I'm pretty sure some of you encountered already) about getting (ghetto) front diff lock.
If you "weld lock" the spider gears and essentially 'disable' the diff you get it locked, while when the front disconnect is disengaged it acts like a normal diff because you don't have the passenger wheel adding Strain to the system.
Could it work? A friend of mine is getting a new diff and we thought of doing it with the old one..
Cheers,
Stas.
Sent from my LG-D855 using Tapatalk
stastyle
by ErikSS » Wed Nov 30, 2016 10:19 pm
Completely locked would add a lot of stress to a weak point in the drive line. I'm not sure I would do that.
by stastyle » Thu Dec 01, 2016 12:52 am
Which is? The transfer case?
I guess it would be harder on turns, but on a loose gravel, sand and mud wont it be okay?
stastyle
by HARDTRAILZ » Thu Dec 01, 2016 12:32 pm
It will still be locked, just not powered. Lot of stress on the diff that is marginal anyway.
by HawkeyeC25 » Thu Dec 01, 2016 10:59 pm
I agree with these guys... the front axle is not that strong to begin with, and when you do use 4wd, your disconnect will not take the added twist of front axles when trying to turn. I think the Tcase would be fine because it would see the same input loads if all 4 tires have traction anyway. But either your diff housing or disco would be the weak link - just a matter of time.
HawkeyeC25
by stastyle » Sat Dec 03, 2016 6:28 am
Got it! Thanks guys!
stastyle
