offroadTB.com • View topic - Taking care of business on the TB
by TBYODA » Sat Sep 14, 2013 10:39 pm
So today I finally got down to changing some fluids, front and rear differentials, oil and transfer case on my 2008 TB. My driveway is at a incline and I normally turn around and drive up the ramps down the driveway, so then the vehicle is level. However with the TB I just push my steel rams as the front wheels touch the edge, I guess the TB is to heavy for the friction to keep the ramps in place. So I had try something else. This what I came up with.
Image worked for this oil change. ;) looking for a better idea. Yea, yea I know with lift you don't need to do this. Lol
So on to the front differential, man the fill plug is one PITA. Was trying and trying did not seem to be moving it at all. Hmm. Here's why.
Image cheap 3/8" extension was twisting it. LOL!
Also while I was under the TB I noticed that it looks like my front differential is leaking, seems to be between differential and oil pan maybe. Will have to keep a eye on it.
No sign of metal in the oil other than normal wear.
Transfer case next, I watched a few YouTube videos on the subject before hand seemed pretty easy 10mm socket and you are good. Well it seems my 08 uses a hex plug, this turned out to be 10mm also, good thing I happen to have one. ;) did txt v7guy asking if he knew. Thanks Jason for the quick reply.
Since the TB was still up the ramps some fluid came out the fill plug, damn looks like normal gear oil or could be that BP stuff. Never trust the other guy. Errr!
Just for fun I pulled the rear differential cover off to have a peek.
Image damn no G80, RPO code was right :(
I know this is pretty simple and old hat for most here but I mainly posted this for the 10 mm hex bolt on the transfer case and that it would be helpful to some one.
by dvanbramer88 » Sat Sep 14, 2013 10:44 pm
I have the same problem with steel ramps like that too. I just push them across the blacktop. In 4WD i can walk right up them no problem.
by TBYODA » Sat Sep 14, 2013 10:47 pm
by dvanbramer88 » Sat Sep 14, 2013 10:50 pm
Bummer. But it looks like your solution did work just fine.
by NC_IslandRunner » Sun Sep 15, 2013 12:08 am
by djthumper » Sun Sep 15, 2013 12:55 am
Yeah I recently did my transfer case and it used the allen wrench.
by v7guy » Sun Sep 15, 2013 5:08 am
Good to see things documented, the more resources we have available to the new guys the better.
by Trail X » Sun Sep 15, 2013 2:01 pm
I've heard that front diff plug can be difficult. An impactor makes short work of it though.
by Shdwdrgn » Mon Sep 16, 2013 10:57 am
How can you tell visually it doesn't have the G80? Anyone have a shot of what the G80 looks like?
Shdwdrgn
Contributing Author
by TBYODA » Mon Sep 16, 2013 11:47 am
by Shdwdrgn » Mon Sep 16, 2013 11:58 am
Ah!!! Yes that looks familiar. Glad to see the new axle I got really does have the G80 as advertised. Thanks for the help!
Shdwdrgn
Contributing Author
