offroadTB.com • View topic - Transfer Case Output Shaft Seal Replacement Rear
by Karo » Fri Dec 28, 2012 2:28 pm
I had a leaking Output Shaft Seal on my Transfer Case. Changed the seal yesterday, it was the first time for me removing the propeller shaft and now i have some questions.
First here is the picture of the leaking seal:
The removed propeller shaft:
First question is what is that bushing inside the transfer case? From viewing the seal it couldn´t have to do with the sealing. The bushing has some deepening that runs diagonal from one side to the other side of the bushing. There are two "deepenings" inside.
Next question is there is a missing spline on the slip yoke but it does n´t seem that it is broken. Is that normal?
Picture here:
I have already installed the new seal but would go safe with some more information from you guys.
Karsten
Karo
by DirtyBacon04 » Fri Dec 28, 2012 3:37 pm
I dont know about the bushing, but the spline looks like a master spline. That way it can only fit in one way. That way everything stays geared the same. Just my best guess.
by Karo » Fri Dec 28, 2012 3:59 pm
Karo
by fishsticks » Sat Dec 29, 2012 3:44 am
Both the ones I have seen are the same way. My thought was that is there to allow a little bit of transfer case fluid in there to lube the slip yoke.
The old Trailblazer -
