offroadTB.com • View topic - Spare Tire mounting - Interior
by SaltWaterDrinker » Tue Dec 04, 2012 2:18 pm
I've been trying to bounce this around in my head, but I feel as if I am missing something.
I love my spare carrier...don't get me wrong. However, I am looking for an alternative to use in my non-wheeling months. Has anyone come up with, know of, or seen a way to mount spare tires on the inside similar to the way Jeep Cherokees have it mounted?
Cheers!!!
SaltWaterDrinker
by navigator » Tue Dec 04, 2012 2:31 pm
I seem to recall some guys have put them on the side and used a ratchet strap between the cargo anchors.
by dvanbramer88 » Tue Dec 04, 2012 2:48 pm
Get your tape measure out. Is the floor to ceiling in the cargo area 32 inches? How about from the back seat to the hatch? And the mouth of the Hatch area? I think most people don't put the tire inside, because it don't fit. :poke:
AND you have a roof basket... Put on your big girl panties and lift that tire up there... :gimp:
by navigator » Tue Dec 04, 2012 3:31 pm
I just went and checked again ( pretty sure I had checked before) and it looks like a 33 will fit.
I have about 34" when I check level from the bottom of the open hatch window to the seat back and I think about 36 from the floor to ceiling. Where I checked is a couple inches from the top of the seat back and there is a small amount of taper back but I think at that point you are higher than the widest point. I didn't think to check at the time how high up from the floor the measurement was. I'll try to get that measurement if I get a chance.
by HARDTRAILZ » Tue Dec 04, 2012 3:53 pm
I have put 4 33s side by side back.there for sure. Pretty sure i stuck 4 35s without rims there too.
by Moots1288 » Tue Dec 04, 2012 4:18 pm
I had my 32 in my truck during tecore...
by Karo » Tue Dec 04, 2012 4:24 pm
That´s my 32" in the back of my Interior:
Karo
by v7guy » Tue Dec 04, 2012 6:02 pm
My favorite part of having the spare on the insideof my S10blazer was putting a slush covered muddy tire inside the truck when I had a flat while driving to work.
Just something to think about.
by SaltWaterDrinker » Wed Dec 05, 2012 11:04 am
Cheers!!!
SaltWaterDrinker
by Gordinho80 » Wed Dec 05, 2012 12:22 pm
I used to have the spare in the cargo area of my TB. If you stand it up between the side tie down spots, you can use a ratchet strap to hold it in place. You'll just get a little rubbing on the headliner near the tailgate door.
Mario -
by SaltWaterDrinker » Wed Dec 05, 2012 12:38 pm
Cheers!!!
SaltWaterDrinker
by navigator » Wed Dec 05, 2012 12:46 pm
I've been thinking of building a platform that my tire can slide under with some storage on the sides and fasten it to the floor. With it fastened the tire can slide in and won't need to be secured with the hatch closed. It would also allow me to quickly remove the tire if I need to get in the lower compartment. It would also allow me to add a few more tie downs to secure gear if needed.
by SaltWaterDrinker » Wed Dec 05, 2012 1:21 pm
Cheers!!!
SaltWaterDrinker
by navigator » Wed Dec 05, 2012 2:54 pm
by SomeOffPave » Thu Dec 06, 2012 6:36 pm
:hijack:
Once or twice there has been discussion* about removing the OEM spare tire carrier and its support so that a hole could be cut in the rear floor and a tray deep enough for the spare tire (laying flat - not upright like Karo posted) lowered into the hole. Then carpet a piece of 3/4" plywood and lay it over the spare. Has anybody done this? Made the tray from scratch or adapt something else?
* Maybe it was on the OS or GMTnation, I cannot remember.
SomeOffPave
by NC_IslandRunner » Thu Dec 06, 2012 8:27 pm
That would be a pain in the ass, get a flat on the trail and have to unpack the entire cargo area just to get to spare. I use to carry my spare on the roof and that was no fun to get up and down but I would put back on the roof before I buried it under my gear.
by chevycrew » Fri Dec 07, 2012 2:59 am
See out the rear? haha. Try having a 40" spare to haul around, only place it fits is on the back covering the rear window. Unless you fold down both rear seats, then it will fit inside.
by HARDTRAILZ » Fri Dec 07, 2012 11:11 am
With my 35 on the drivers side of the bumper, I really lost little visibility. Really glad we went that way and not the middle or passenger side.
