KaRo
bartonmd wrote:I haven't seen that one, before. I had considered making a skid that goes from the rear of my oil pan skid to the trans crossmember, but our transmission sits so high above the frame that we don't have much need for protection back there. Also, since it's a pretty good span, there's not a whole lot that you're going to be able to do to take any REAL amount of weight, even with the ~4.6mm steel that I use, even with flanges on it. I'll make one if it turns out that there's a market and/or a need for it, but I just haven't seen it yet.
Moots1288 wrote:All it takes is one rock to go up the between the frame. I am interested in a trans skid if there ever is one made
v7guy wrote:Matt was talking about this earlier this evening and I was envisioning a plate that went from frame rail to frame rail. That looks a good bit more simple.
v7guy wrote:Would the cat end up close to the skid plate if it went straight across? I know jeep had that recall for the 2010 Wranglers because the redesigned cat location wasn't adjusted for in the skid plates. Supposedly stuff could get caught inbetween the plate and cat and maybe catch fire.
It seems to be relatively common for skid plates to be made specifically to protect the cat for the jeep guys and they seem to be a flat plate usually. Obviously a full plate would be massive and expensive to ship.
Care to share your thoughts on the design decision?
JamesDowning wrote:Karsten, that looks very similar to one that I found a while back made in Israel. I'd have to root through my emails sometime to find it. Mario might recall the name. Might be cheaper to ship to you.
Gordinho80 wrote:JamesDowning wrote:Karsten, that looks very similar to one that I found a while back made in Israel. I'd have to root through my emails sometime to find it. Mario might recall the name. Might be cheaper to ship to you.
Found it...
http://www.asfir.com/catalogueEN.asp?co ... combo1=110
HARDTRAILZ wrote:Guess i need to cleanup my undercarriage.
