New scanner for the TB
by TangoBravo » Tue Sep 18, 2012 5:20 pm
Picked this little guy up today. So far I am very impressed, anyone else use this kind before?
Not sent from a Iphone.
TangoBravo
by Nakashige » Tue Sep 18, 2012 6:46 pm
Blue Point owned by Snap On right?
Nakashige
Vendor
by TangoBravo » Tue Sep 18, 2012 6:55 pm
Yeah
TangoBravo
by dvanbramer88 » Fri Sep 21, 2012 11:00 am
Nakashige wrote:Blue Point owned by Snap On right?
Blue point is Po-Boy snap on. Yeah.
by TangoBravo » Fri Sep 21, 2012 11:04 am
Sure is, but dang the models above this one was way more expensive and did the same thing as this one well unless I went with the one that was 1400.
TangoBravo
by Trail X » Fri Sep 21, 2012 11:11 am
Looks decent. Can you command actuators? or is it read only?
by The Roadie » Fri Sep 21, 2012 11:25 am
Looks like read only, but it talks to the ABS module. Also graphs stored data like a little oscilloscope. Going for $100-150 on Ebay.
by TangoBravo » Fri Sep 21, 2012 12:04 pm
Yeah the only ones I found cheap on ebay wern't the pro which does obdI and obdII as well as ABS, the only pro one I found was going for 300 but that stuff changes daily and I have a snapon account so it was just easier to get one off the truck since I also needed it ASAP.
TangoBravo
by Darkrider_LS » Fri Nov 30, 2012 6:54 am
Kinda late into this but does the one you got do obd I and II?
Powered by Detroit Diesel
Darkrider_LS
by TangoBravo » Fri Nov 30, 2012 12:04 pm
Yes as well as ABS it also records and stores data for later review.
TangoBravo
by Darkrider_LS » Fri Nov 30, 2012 12:30 pm
TangoBravo wrote:Yes as well as ABS it also records and stores data for later review.
Nice! Where did you pick it up?
Darkrider_LS
by TangoBravo » Fri Nov 30, 2012 7:14 pm
Snapon
TangoBravo
by Conner299 » Sun Dec 02, 2012 9:33 pm
Sounds like it does all the same things the Torque Pro app will. That was only about 30$.
Conner299
by TangoBravo » Sun Dec 02, 2012 10:04 pm
Conner299 wrote:Sounds like it does all the same things the Torque Pro app will. That was only about 30$.
Not exactly, as the scan tool has software built in that installs onto my laptop and does quite abit more then the torque app. I like the torque app and it is my go to tool, but when I really need to dive into a project my scan tool is the only way to go.
TangoBravo
