Oil on #3 spark plug
by 06MidnightBlue » Tue May 08, 2012 10:38 am
As the title says, I was changing the spark plugs last night and there was oil on the number 3 plug and a tad bit in the valley. Could this be a valve cover gasket and spark plug valley gaskets?
06MidnightBlue
by spalding1028 » Fri Jun 01, 2012 6:44 pm
From what I've read, that's what it seems to be most of the time. There are 6 gaskets, one for each plug well and they seem to wear out and leak oil into the plug well. Mine had that issue on #3 and #4 I put the plugs back in and checked them a week later. They came out clean so I knew it wasn't any type of head gasket/piston ring issue.
spalding1028
by 06MidnightBlue » Thu Jul 12, 2012 3:04 pm
Just to give everyone an update...
I had the spark plug valley gasket replaces. As most of you know this also replaces the valve cover gasket by default. Its been about 2 months and have had no problems since.
06MidnightBlue
by Trail X » Thu Jul 12, 2012 3:32 pm
Was the oil actually causing any problems? My old car leaked some, but it was never really a worry.
by 06MidnightBlue » Thu Jul 12, 2012 3:40 pm
I was curious to this as well. It seemed that when it was leaking, the TB had a little misfire on start up. Now since I've had it fixed, I havent had the problem.
So to answer you're question...it could have been causing a slight misfire.
06MidnightBlue
