Need Help with Seafoam.
by TangoBravo » Mon Oct 10, 2011 1:17 pm
So I got a bottle of seafoam and wanted to do the vacume line treatment, But after looking around under the hood I really wasn't sure which I should use. So does anyone who have used this tell me what there preffered method is and what vacume line they use? I want to make sure I do it right and get a good treatment. Thanks for your help.
TangoBravo
by Saxis » Mon Oct 10, 2011 1:23 pm
Break booster is the one I've always used...
Saxis
by bdp1978 » Mon Oct 10, 2011 1:27 pm
Agreed, just pull the line off your brake booster and slowly pour in with the engine running.
bdp1978
by ruffryder59 » Mon Oct 10, 2011 7:28 pm
I two have always used the brake booster line. You will probably want someone to help you. As soon as it starts drawing it in the motor will want to stall. You will have to keep the rpms up and do a little at a time. Oh yeah and park somewhere away from houses it will smoke like all get out.
ruffryder59
by Trail X » Mon Oct 10, 2011 9:02 pm
Won't that only treat the cylinders beneath the brake booster connection? I like the idea of the spray-can version of seafoam with the snake line thing.
http://www.seafoamsales.com/how-to-use- ... spray.html
For some reason I feel better about the even delivery of this method, versus the vac line delivery.
by fishsticks » Mon Oct 10, 2011 9:19 pm
JamesDowning wrote:Won't that only treat the cylinders beneath the brake booster connection? I like the idea of the spray-can version of seafoam with the snake line thing.
Since I don't have a MAF, I hook the snake line things to the TB and spray a little over half a can in with the motor running. Most even distribution I can think of on our motors.
I use the other ~half to clean the backside of the TB.
(I use the brake booster or the front vacuum port on V8 motors.)
by TangoBravo » Wed Oct 12, 2011 3:08 pm
Thanks for all the input guys, That was my main concern(even distribution) about using a vacume line.
TangoBravo
