Front Seat Replacement
by Nakashige » Tue Aug 23, 2011 6:52 pm
Has anyone done seat replacement for front seats? Aftermarket like Corbeau or such?
Nakashige
Vendor
by chevycrew » Tue Aug 23, 2011 7:07 pm
Im guessing, no. But you never know. Replacing the front seats will render the air bag system inoperable unless you can bypass the seat stuff.
by Diacom » Wed Aug 24, 2011 10:34 am
Suggestion due to the air bag dilema, just go in and have your seats reupholstered with more padding to act as bolstering. It's about the only thing I could think of short of bypassing the airbag i'd rather keep.
by Nakashige » Wed Aug 24, 2011 10:37 am
The issue I am having is the electric seat and the bracing to the acuator under it that moves the front of the seat up and down. The front mounts are broken. I am a big guy 230 pounds and trying to figure out what the best option might be.
Nakashige
Vendor
by Diacom » Wed Aug 24, 2011 5:01 pm
Someone may chime in with more information, but are all the drivers side TB seats electric? Maybe what you need is a bracket from a non electric seat that doesn't have this inherent weakness. Maybe from a Colorado or another model that will work.
Of course this is moot if you wish to keep the electric seat adjustments. Then maybe it just needs some re-enforcement added so that it is stronger.
by Gordinho80 » Wed Aug 24, 2011 5:13 pm
Non-electric seat in my 04... I'm a big dude... bigger then you.. and I've been driving it without issue since Jan 06... nothing moves.
by Flying Monkey » Wed Aug 24, 2011 6:01 pm
Yeah non electric in my 04 as well. Im not a big guy (170 lbs) but maybe you can hunt some salvage yards for a non electric seat
Flying Monkey
by djthumper » Wed Aug 24, 2011 7:07 pm
I thought I read someplace that manual seats for the driver was an option. That may be for the 06 and newer though. You would think that you could take a seat out of another TB and it would work.
by OregTrailBlazin » Thu Aug 25, 2011 4:32 pm
You can also run down to an upolstery shop. This is actually a pretty common problem (worked at one in highschool). They will pull the cover, and foam off, weld up the problem area, even reinforce it if need be, then slap it back together. It was usually pretty cheap because they are not out any material, and labor rates are fairly cheap.
Johnny Kurz
General Manager
541-474-2879
Wheeler's Off-Road Inc.
Our Vendor Section
OregTrailBlazin
by NC_IslandRunner » Thu Aug 25, 2011 4:46 pm
Nakashige wrote:The issue I am having is the electric seat and the bracing to the acuator under it that moves the front of the seat up and down. The front mounts are broken. I am a big guy 230 pounds and trying to figure out what the best option might be.
OregTrailBlazin wrote:You can also run down to an upolstery shop. This is actually a pretty common problem (worked at one in highschool). They will pull the cover, and foam off, weld up the problem area, even reinforce it if need be, then slap it back together. It was usually pretty cheap because they are not out any material, and labor rates are fairly cheap.
This might be the best option, I'm 275 and I haven't had any problems with my electric seat yet and I've had it 4yrs 100,000 miles, but I was only about 210 when I bought the truck.
by Diacom » Thu Aug 25, 2011 10:01 pm
There we go, problem solved :friday:
