offroadTB.com • View topic - Teflon grease VS Silicone grease. Pros and cons?
by bobbyblaze » Fri Sep 25, 2009 6:23 am
OK, I just picked up a new set of OE stabilizer bar to frame bushings and need to grease them. The dealer suggested using silicone grease but the guy who told me that dosen't seem to be wrapped too tight :? . I have used Teflon grease in the past for polyurethane bushings and have enough leftover to do this job. :mechanic:
I believe that the teflon grease will be safe for the factory bushing (could be wrong). Are there any other positives or negatives to using either of them ? :?:
bobbyblaze
by bgwolfpack » Fri Sep 25, 2009 12:30 pm
by bobbyblaze » Sat Sep 26, 2009 1:06 am
bobbyblaze
by bgwolfpack » Sat Sep 26, 2009 1:52 pm
bobbyblaze, I found a site you may be interested in looking at.www2.dupont.com/Krytox/zh_CN/assets/downloads/H-58505-1.pdf
by bobbyblaze » Sat Sep 26, 2009 2:03 pm
Just looked at it. Good knowlege. Are you using used Krytox ?
bobbyblaze
by bgwolfpack » Sat Sep 26, 2009 2:18 pm
by bobbyblaze » Sat Sep 26, 2009 6:42 pm
I thought I had enough teflon grease left over from a previous sway bar job. Not the case so I just used Red lithium grease for the bushings and to top off the end links in the zerk fittings. There was rain in the forecast today (no garage) so I used what I had. Just started to rain when I was cleaning up. Lucky me :excited: .
In the not too distant future I'll be doing the rear end links and possibly the frame bushings back there too. I have time to research some lubes. Maybe even give that Krytox a shot.
bobbyblaze
by bgwolfpack » Sat Sep 26, 2009 9:34 pm
I did a little more research on Krytox. If you try it please let the rest of us know when you use it. I at least will have more questions about it.
Glad you got done in time not to get soaked, but around here we don't think about that sort of convenience. :shock:
by Gordinho80 » Tue Sep 29, 2009 9:10 am
Bob, how's the front sound since replacing the links and the bushings?
Mario -
by bobbyblaze » Tue Sep 29, 2009 8:01 pm
(38.97 KiB) Downloaded 710 times
(36.5 KiB) Downloaded 710 times
bobbyblaze
by Trail X » Wed Sep 30, 2009 8:49 am
My understanding is that it's best to disconnect the front swaybar and leave the rear in place due to CG heights and suspension geometry.
By unhooking the fronts, you're actually able to get similar articulation to the rear axle. As it is, the rear is much more flexy than the front.
by bobbyblaze » Wed Sep 30, 2009 5:28 pm
bobbyblaze
by Gordinho80 » Wed Sep 30, 2009 5:39 pm
I'm in for the front links, rear links, and SLIDERS!!! LOL
Mario -
by bobbyblaze » Wed Sep 30, 2009 6:19 pm
It woild be real easy for me to mod my brand new moog end links :geek:
bobbyblaze
