I open the gas cap, pull the pump relay, I start the tb and let it die, and then I push the schrader valve in on the connection of the filter. A little gas came out so I figure its drained.
WRONG!!!!!!
Apparently there was a some debris in the valve that didn't let the fuel pressure release. When I removed the first line gas sprayed all over my face, my shirt, and went down into my arm pit where is mixed with my deodorant and burned my arm pit. It f ing hurts.
So the moral of this story is, double check everything
