offroadTB.com • View topic - It's been a nice week.
by SteveTB03 » Thu Jul 15, 2010 3:34 pm
So this week I decided to buy a few toys and repair/maintain my TB, So this is how it followed.
Monday: Got a custom tune from ScarabEpic22 on the OS, It is like night and day between the stock tune and his!! :excited: I also found out my T-stat is bad.
Tuesday: Bought a new T-Stat, Hella 500FFs, seafoam, fuel injector cleaner, air filter, and a full Royal Purple oil change with K&N oil filter. I did the seafoam and damn was there a lot of smoke!! I guess that's what happens when you never use it in 113000 MI :wallbash: and I changed the oil and used the fuel injector cleaner.
I also TRIED to install the hellas but couldn't figure bit out as I was tired so I went to bed.
Wednesday: After talking to Gordin I wired up the lights no problem. Then it was off to the dealership to get a MEGAFUSE and then Autozone to do a full brake job front and rear.
So this week has been pretty good and I love how the seafoam makes your engine idle SOO much smoother.
WARNING
Now after I changed the brakes now my emergency brake works no more maybe one of you guys know what to look for or anything???
Go Big & Go Broke
SteveTB03
by Trail X » Thu Jul 15, 2010 4:14 pm
by SteveTB03 » Thu Jul 15, 2010 4:21 pm
I was actually thinking that the e brake pads are just too worn to engage I mean hell I've never even replaced those since I bought my truck used on October 31st 2006.
Go Big & Go Broke
SteveTB03
by Trail X » Thu Jul 15, 2010 4:25 pm
Did it work on your last brake rotors?
by SteveTB03 » Thu Jul 15, 2010 4:35 pm
Yeah it worked perfectly fine on the last set I know I did accidently move the e brake pads (shifted them a bit) when I took off the old rotors just because I was looking at them. Could that be what has caused the now not working e brake?
Go Big & Go Broke
SteveTB03
by SteveTB03 » Thu Jul 15, 2010 4:40 pm
I just checked it out just now and the e brake BARELY engages when I pull it up as far as the handle will go but not enough to stop my truck on an incline that's about a 20-30 degrees
Go Big & Go Broke
SteveTB03
by fishsticks » Thu Jul 15, 2010 4:44 pm
You need to pull the rear rotors off and adjust the tensioners that are on the axle.
EDIT: How much did Scarab charge for his tune? I'm headed up to Seattle again soon.
The old Trailblazer -
by SteveTB03 » Thu Jul 15, 2010 5:34 pm
Go Big & Go Broke
SteveTB03
