offroadTB.com • View topic - Completed: Lengthening the SMAXX rear sway bar end links.
by MrSmithsTB » Wed Sep 01, 2010 7:00 pm
I have wanted to do this for a while, and finally remembered to pick up the parts while I was at Lowes. Since the MAXXlinks are only rated for stock-2" of lift, I thought the 3.5" from Marks spacer and the Z71 springs created the need for a little modification. Assuming that you already have SMAXX links, this can be done in 1/2 hour and is very easy on the wallet.
Needed:
(2)3/4"x4" galvanized plumbing nipples
3/4" wrench
9/16" wrench
I started by removing the end links one at a time with the 3/4" wrench. Here's what it looks like after a year on the truck:
Using the 9/16" wrench, I removed the bottom nut and disassembled the bottom half of end links. The inside washers have to be inverted, otherwise the assembly is too long to use the original bolt. So I inverted the top inside washer, replaced the original sleeve with this:
I inverted the bottom inside washer, reinstalled everything else just as it came off, and loosely attached the bottom nut:
Reinstalled on the truck and they are good to go. Overall, I gained @1" inch of length, and they are slightly more rigid because of the nipple I used.
Back on the truck:
by irishboy02 » Thu Sep 02, 2010 2:22 am
Nice!! Now does this tuck your swaybar tighter to your rear diff? Yea right? Nice cheap easy mod. I wonder if you could basically just build a set like that from scratch?
Good work Bob!
2003 GMC Sierra z71
7" FTS lift
irishboy02
by Trail X » Thu Sep 02, 2010 7:41 am
by MrSmithsTB » Thu Sep 02, 2010 11:25 am
I'm definitely not a fan of that much rust. As it stands, I'm probably just going to replace all of that with galvanized. The sway bar is no closer to the pumpkin, but the links are nowhere near as close to their flex extension as they were at resting height before.
by Trail X » Thu Sep 02, 2010 11:36 am
by HARDTRAILZ » Thu Sep 02, 2010 9:40 pm
I do wish someone made a decent product for us.
Nice job on making a go of it yourself. :cheers:
by MrSmithsTB » Fri Sep 03, 2010 1:37 am
by Zero » Fri Sep 03, 2010 7:44 am
What ever happened to Neil??? wasnt he making a nice set for us that were longer too??? If he isnt, then maybe we can get barton to Jump on this.
by HARDTRAILZ » Fri Sep 03, 2010 8:20 am
He promised alot and then did not deliver. I told him what they needed to fit right and he kept telling me the parts were coming. Never showed. I snapped a third bold at Tecore and took them all off after that. Have not heard from him since the last time I asked about the parts to make them fit right. Bushings would push out, they did not fully line up. I tried to explain what was needed and he seemed to grasp what I was thinking and would tell me the parts were coming, but the last thing I got were some 3/8's hood pins and they didnt fix them.
I did not have that much invested so I tossed them in a drawer and chaulked it up to experience.
by Blask3 » Tue Sep 07, 2010 12:33 pm
That is a great idea. Good job on taking the ball and runnin with it. :cheers:
The only Lifted TB in the Valley
Blask3
