Possible electrical issue, need help
by Dirtyd » Tue Nov 26, 2013 8:14 pm
The last couple days when I go to turn my car off ,I turn the key in the car will stay running and going to limp mode and finally die. When I go to start at the next morning the vehicle will be dead. It has a brand new battery. I have no idea what is causing these issues. Any help Will be much appreciated.
You Only Live Once
Dirtyd
by The Roadie » Tue Nov 26, 2013 8:50 pm
Seems obvious to start with the ignition switch. How-to articles have been posted on GMTNation and that "other site".
by ErikSS » Tue Nov 26, 2013 9:01 pm
The Roadie wrote:Seems obvious to start with the ignition switch. How-to articles have been posted on GMTNation and that "other site".
:Iagree:
It wouldn't be the first trailblazer needing an ignition switch. Hatchet just put one in his truck about a week ago.
by Dirtyd » Fri Nov 29, 2013 8:47 pm
Tried the ignition switch with no results. It still is having major problems
You Only Live Once
Dirtyd
by The Roadie » Fri Nov 29, 2013 10:42 pm
The wiring color code at the switch has been posted a few times on GMTN and trailvoy. Use your meter and confirm the voltage on those pins in the various ignition modes.
by Dirtyd » Mon Dec 02, 2013 9:48 pm
Solved! Thanks roadie! It ended up all being caused by a badly corroded air pump relay.
You Only Live Once
Dirtyd
by The Roadie » Tue Dec 03, 2013 1:33 am
I didn't help at all.... But thanks for the report. I can easily see how it would happen, but don't remember ever reading about this exact fault.
