Rear differential question
by dvanbramer88 » Sat Nov 26, 2011 6:13 pm
Can i take the G80 out of josh's 2002 TB and put in his new 2003 TB that doesn't have the G80?
Is it as easy as switching the carriers and guts? or would just swapping out the rear axles be easier? (i did see the guide about repairing the G80)
by Trail X » Sat Nov 26, 2011 7:41 pm
It would be easier to swap the entire axle.
There is a lot involved with a carrier swap... shims, backlash measurements, etc.
by dvanbramer88 » Sat Nov 26, 2011 9:42 pm
thanks man. I wasn't sure if it was just a bolt off bolt on swap or they were significantly different. Swapping the axles wouldn't be to hard, especially if it was done while installing a lift kit. Kill 2 birds with one stone...
by v7guy » Sat Nov 26, 2011 9:42 pm
James is right, you would save a large amount of time just swapping the axles.
by DmccartneyFF2TB » Sat Nov 26, 2011 9:51 pm
As long as it has the same gearing.
Dame
BDS,ROUGH COUNTRY,
Smitty Build XR-C8 Winch
www.wm4x4.com
DmccartneyFF2TB
by Trail X » Sun Nov 27, 2011 10:45 am
DmccartneyFF2TB wrote:As long as it has the same gearing.
Haha, good point. I kinda figured that was a given, but now that you mention it, it may not be.
by dvanbramer88 » Sun Nov 27, 2011 1:15 pm
Gearing didnt even cross my mind, thanks.
by The Roadie » Sun Nov 27, 2011 6:24 pm
That would have been a world-class "aw shit" moment! Engage 4HI and forward progress halts with a CLANK! :wallbash:
by v7guy » Mon Nov 28, 2011 1:33 am
Um yeah, not the same gears would be bad
