The Mysterious Part Number Thread
by fishsticks » Mon Oct 24, 2011 3:24 pm
Do we have one of these? No? We should.
Inspiration for thread: I had to dig around for awhile looking for a PN for the rear xfer case seal. Finally found a PN buried in one of Bill's posts on the OS from THREE YEARS ago.
If you like to deal shop (and I do) sometimes looking for a part by its part number (instead of its application) on the internet will save you BIG $$. Also, with Compnine shutting down, GM part numbers just became a lot harder to come by.
Post up any obscure(or common) part numbers you've come across and help out the next guy. I'll add them to the list here.
Differential, Front
  • Pinion Seal: Timken 8611N
Differential, Rear, 8.0"
  • G80 Clutch Pack, Left: GM 12479036
  • G80 Clutch Pack, Right: GM 12479037
  • G80 Cam Plate: GM 12479048
  • G80 Governor/Ratchet Kit: GM 12471530
Transfer Case
  • Rear Output Seal: SKF 19317
Steering
  • Tie Rod, Outer, Left, 16mm thread: Raybestos 401-1886
  • Tie Rod, Outer, Right, 16mm thread: Raybestos 401-1887
  • Tie Rod, Inner, 16mm thread: Raybestos 401-1888
  • Tie Rod, Outer, Left, 14mm thread: Raybestos 401-1866
  • Tie Rod, Outer, Right, 14mm thread: Raybestos 401-1867
  • Tie Rod, Inner, 14mm thread: Raybestos 401-1870
by The Roadie » Tue Oct 25, 2011 11:02 am
