Rack and pinion leaking??
by DmccartneyFF2TB » Sun Jul 24, 2011 8:02 pm
Any one replace a rack and pinion? Any advice.
Dame
BDS,ROUGH COUNTRY,
Smitty Build XR-C8 Winch
www.wm4x4.com
DmccartneyFF2TB
by Diacom » Sun Jul 24, 2011 11:38 pm
If not, this would be a perfect time for a write up...
by fishsticks » Sat Jul 30, 2011 3:06 am
I've had mine mostly off. It's pretty straight forward once you get under there and look at it. Buy a unit with 16mm threads instead of the 14mm.
I've been itching to pick up a salvage EXT rack and see what the differences are (they are different GM PNs).
by DmccartneyFF2TB » Sat Jul 30, 2011 2:06 pm
I ended up buying Lucus powerstering sealer ( renews rack and pinions or ur money back) well it worked haha so I'll try that till I can find a new one from a junk yard.
Dame
BDS,ROUGH COUNTRY,
www.wm4x4.com
DmccartneyFF2TB
by JustBlaze05 » Thu Aug 04, 2011 11:21 pm
Had this same problem, leaking from the end seal. PSF with stop leak seems to have sealed it temporarily.
JustBlaze05
by DmccartneyFF2TB » Thu Aug 18, 2011 6:26 pm
I got some luces power steering sealer and it has worked great.
Dame
BDS,ROUGH COUNTRY,
www.wm4x4.com
DmccartneyFF2TB
