Broken Transfer Case & Upgrade to 4.10 gears
by Gordinho80 » Sun Sep 08, 2013 11:20 am
Something tells me the dealer gave me the wrong part # for the rear flange/yoke.
The joints and strap kits are from RockAuto. I called a dealer and asked for the flange, it was crazy expensive. Asked for the part #, then ordered that part on GM Parts Direct. I thought I was crazy so I matched it up to the old one... and its wrong.
Now what???
Robert, I'm going to get a pic of the wires I need. Can you check for the wires and for a good flange from the rear axle? You'd probably need an impact gun to get the nut off of it, though.
by Regulator1175 » Sun Sep 08, 2013 11:35 am
Gordinho80 wrote:Any suggestions on how/where I can get the plugs with pigtails from the TC harness? When mine broke, it took out one of the plugs. It's the green and purple 2 wire plug.
If anyone has a junk yard where they can cut one off... No luck in my area...
PM me an address and I will get the plug as well as the rear flange in the mail to you.
by Gordinho80 » Sun Sep 08, 2013 12:59 pm
Thanks man! Let me know what the cost is...
by Gordinho80 » Wed Sep 11, 2013 7:38 pm
Front end is all back together!!!!
Rack and Pinion will be here Friday...
by Trail X » Wed Sep 11, 2013 9:43 pm
I think you mean ring and pinion.
by Gordinho80 » Wed Sep 11, 2013 10:02 pm
Brain fart... My bad!
by Gordinho80 » Fri Sep 13, 2013 1:24 pm
4.10s are here!!!!!!
Now what do I need to install these? LOL
by v7guy » Fri Sep 13, 2013 1:38 pm
I was hoping you would take dozens of pics and painstakingly document it. We need experienced people to post big ole how-to articles with immense detail.
Personally I've been having a hard time taking enough pics, editing them and still being specific.
Seriously, it's why I take so many pics. I haven't had need to do this job yet. Hopefully you can do a better job than me. lol
by Gordinho80 » Fri Sep 13, 2013 1:40 pm
I'm horrible at taking pictures as I go. I took NOTHING so far. Once I get going with the wrenches in my hands, I put everything else to the back of my mind. That, and I'd rather not handle my camera with greased up hands...
by bgwolfpack » Fri Sep 13, 2013 1:41 pm
Pics! Pics! Pics!
So waiting to see and read your whole write-up! :)
Please!
by Gordinho80 » Fri Sep 13, 2013 1:45 pm
My buddy is probably coming over tomorrow to give me a hand with this. He's a former mechanic, turned Service Manager. He hasn't touched wrenches in years, but he has done gears before. And my neighbor used to have a 60s camaro that he did gears on, so he'll be popping over.
If they are here doing most of the work, I'll shoot pics!
by Gordinho80 » Thu Sep 19, 2013 12:37 pm
Well, slight change of plans. I dropped the axle off with a mechanic (friend of a friend). He's doing all the labor, including replacing the axle bearings and seals, and all other bearings. I should be picking up the fully rebuilt axle on Saturday!
All I'd have to do is bolt it on and go! Straight to Firestone for an alignment! I goofed up pretty bad when I put the front end back together. I left off the toe adjustment bolts that hold the lower control arms in place. I tried to move the truck because I was supposed to have my driveway sealed, and the steering got kicked out of whack pretty bad. Front looked like this: \ / instead of | |...
Got the bolts back and on straightened wheels to sight... enough to get it to shop for alignment once its done.
Thanks again, Matt, for the yoke and the wire!
by Gordinho80 » Thu Sep 26, 2013 12:02 pm
Ok. The yoke that Matt sent won't work. Slipped my mind that the 8.6 rear has larger spline pinion. I need to order a new yoke but dealers won't give me part # without the last 8 digits of a VIN. I don't have an EXT VIN. Can anyone help me out?
by dvanbramer88 » Thu Sep 26, 2013 12:12 pm
If I see an EXT TB in the parking lot at school, I'll grab it for ya.
Mike Barton's has the 8.6 from the factory because it is 2006 V8. He can probably help you faster than I can
by bgwolfpack » Thu Sep 26, 2013 12:16 pm
by Gordinho80 » Thu Sep 26, 2013 12:36 pm
Pretty sure its the 30 spline, yes. But if I can get the GM part #, i might be able to get it locally for same price. Know a guy who knows a guy at a Chevy dealer...
by bgwolfpack » Thu Sep 26, 2013 12:42 pm
Gordinho80 wrote:Pretty sure its the 30 spline, yes. But if I can get the GM part #, i might be able to get it locally for same price. Know a guy who knows a guy at a Chevy dealer...
Know a guy who knows a guy, ok...couldn't imagine you buying anything from a dealer.
by navigator » Thu Sep 26, 2013 3:58 pm
some of the dealer websites have vins, if all else fails you might be able to find an EXT that way.
by bgwolfpack » Thu Sep 26, 2013 4:04 pm
Philbertos thread GM Vehicle History Requests may help you if you can find where the vin #s are kept. :)
by Gordinho80 » Thu Sep 26, 2013 4:22 pm
As of right now, the mechanic who is setting up the axle for me is going to attempt to chase out the 1 broken bolt from the original yoke. Then drill out all 4 holes to remove the threading. Once done, I would use grade 8 bolts/nuts in place of the OEM strap bolts threaded directly into the yoke.
This should work just fine, I feel.
