SOLD: Front Springs Moog 81114 - $40.00
by mikekey » Mon Sep 16, 2013 7:48 pm
Sold
by TBYODA » Mon Sep 16, 2013 9:50 pm
mikekey wrote:Anyone interested? I have two pair of these stupid springs. Front Springs Moog 81114
$40.00
Doing a quick search do these = 84? Shipped?
by navigator » Tue Sep 17, 2013 8:21 am
if I remember right they are about the same stiffness as an 86 but with their extended length they likely perform similar to an 88 or 89.
If you are still un-lifted they would likely get you at least 1.5 lift depending on your current springs.
A lot of the info is consolidated in this thread
viewtopic.php?f=15&t=3366&hilit=moog+springs
by mikekey » Tue Sep 17, 2013 8:36 am
Yeah, these are heavy. I'll have to go get it weighted at UPS.
by TBYODA » Tue Sep 17, 2013 9:59 am
navigator wrote:if I remember right they are about the same stiffness as an 86 but with their extended length they likely perform similar to an 88 or 89.
Yea I was looking at that post but was having hard time understanding it all. IIRC my fronts are 83.
by navigator » Tue Sep 17, 2013 10:24 am
so if you check the OEM spring chart, going from an 83 to an 86 would get you about 1/2" of lift.
The Moogs are about 1.25" longer than the stock springs so you would likely see about 1.75" of lift.
Also since there is a bit of a lever effect you would likely get a little more.
I would guess you would end up with about 2". If you wanted a little more you could always get a spacer from MarkMc or make one out of some cutting board.
by HARDTRAILZ » Wed Sep 18, 2013 10:31 am
navigator wrote:so if you check the OEM spring chart, going from an 83 to an 86 would get you about 1/2" of lift.
So if I go from the 88s I am running to the 114 in the garage, I will get another 1.25 inches of lift?
by navigator » Wed Sep 18, 2013 1:13 pm
HARDTRAILZ wrote:So if I go from the 88s I am running to the 114 in the garage, I will get another 1.25 inches of lift?
looking at the chart, switching from an 88 to an 85/86 would be about 1/2" of loss.
the Moogs are about 1.25 longer than stock so if my logic is right you would end up with about .75" lift.
by TBYODA » Tue Sep 24, 2013 5:15 pm
Would these work in the rear?
by Moots1288 » Tue Sep 24, 2013 5:28 pm
TBYODA wrote:Would these work in the rear?
No
by mikekey » Sun Sep 29, 2013 7:25 pm
$40 shipped anywhere in the lower 48.
by Moots1288 » Sun Sep 29, 2013 7:32 pm
mikekey wrote:$40 shipped anywhere in the lower 48.
No Alaska?! Damn
by ErikSS » Sun Sep 29, 2013 9:32 pm
I'm trying to put all the information together. Is it fair to say that the springs would be softer at a heigher height than the 88/89?
by HARDTRAILZ » Mon Sep 30, 2013 5:41 am
That's what navigator told me.
by HARDTRAILZ » Mon Sep 30, 2013 1:40 pm
HAHAHAHA Wow. Do some reading.
by Regulator1175 » Mon Sep 30, 2013 1:48 pm
Yes, they will. It's the same springs I am running. You should totally buy them!
by Moots1288 » Mon Sep 30, 2013 1:50 pm
Haha is that how you got that awesome lift?
by mikekey » Mon Sep 30, 2013 1:53 pm
Think I'm going to put one of the sets on the TB this week, might as well use it tell the Radflo group buy goes thru.
by HARDTRAILZ » Mon Sep 30, 2013 1:59 pm
Since navigator told me I would get more lift than my 88s...I keep thinking of putting mine on. Only had em for a year or two.
by Regulator1175 » Mon Sep 30, 2013 2:00 pm
Yup, strut assemblies in both the front and rear for the win!
Sent from my SCH-I545 using Tapatalk 4
