offroadTB.com • View topic - No Body Lift with 5.3L V8?? No more 3" Body Lifts??
by HawkeyeC25 » Thu Nov 12, 2015 12:40 am
Hello all,
I'm about to pick up a 2005 Trailblazer EXT with the intention to lift and put 32 or 33" tires on. I've been through ALL of these forums and I have a couple questions left unanswered... hopefully you can all help!
1) The 3" Body Lift Kits seem to have gone away since 2012. WHAT HAPPENED? Does anyone still make them?
2) The EXT I'm purchasing has the 5.3L V-8! But the only body lifts I can find is the 2" from Zone Offroad, but it says it's for 4.2L ONLY? Does anyone know why I couldn't use this kit on the 5.3L? I think I read somewhere there is a mod you must do for the radiator bracket?
3) I was planning to do the 3" lift kit and the MDB steel bumper kit for the 3" lift. But now it seems like there is a mismatch in the market - 3" body lift MDB bumper kits but only 2" body lift kits available. And no 2" MDB bumper kit... :scratch: HELP!!
HawkeyeC25
by HARDTRAILZ » Thu Nov 12, 2015 9:44 am
No demand for them really to get someone to stock them. They were really only done by two people and with random suppliers. No one makes one now, but it is being attempted currently.
You can do the body lift with a 5.3.
Build your own or slap some JK frame Horns on and the frame rails and bolt on one of the million or so available for that platform. They actually fit pretty good.
by bartonmd » Thu Nov 12, 2015 5:51 pm
I assume that my message back to you on Facebook this morning answered your questions?
by ErikSS » Thu Nov 12, 2015 9:33 pm
The radiator bracket will require modification for a V8 body lift. I think I had to lengthen mine. It's been a while.
by v7guy » Fri Nov 13, 2015 12:12 am
I pieced my body lift together, just order the bolts and the 3" blocks. Relocating the bumpers is a little more difficult, but it's not a huge deal
by HawkeyeC25 » Fri Nov 13, 2015 7:23 pm
HawkeyeC25
by Aries » Fri Nov 13, 2015 9:44 pm
The bolts that came with the kit I purchased were tagged with a John Deere part number.
Aries
by v7guy » Sat Nov 14, 2015 2:14 pm
I don't remember the bolt lengths or sizes off the top of my head, but I do remember finding em on some ancient post on the old trailblazer/envoy board.
by Jedidaddy1 » Sat Nov 14, 2015 6:52 pm
I have a set that I just pulled out and did my one inch body lift, I'll measure and post length they are at the shop so it will be tomorrow (Sunday). As far as the front and rear bumper brackets you will have to fab something up not to hard. Also you will need to extend your heater core hoses and fuel filler neck. Biggest thing will be a steering shaft extension.
Jedidaddy1
by navigator » Mon Nov 16, 2015 9:37 am
With the 2" Zone I had no issues with h heater core or filler neck. I might have had to disconnect a support for the filler neck but that was all.
Besides blocks, steering extension, bolts and bumpers, the radiator is all I remember doing. The rear bumper was the most nerve racking, making sure the cuts were right on the stock tow receiver mount.
by HARDTRAILZ » Mon Nov 16, 2015 9:46 am
by Jedidaddy1 » Mon Nov 16, 2015 10:49 pm
My hoses may have been cut by the po not sure, but I needed to change them to longer ones. As far as the body bolts the stock set have 2 different sizes. markmc » Wed Mar 23, 2011 4:47 am
Not sure what the stock bolt lenght is, but here is the length i used for the 3" body lift.
The very front 2 body mount bolts are m12x230
The rear 10 body mount bolts are m12x190
There are also 2 front bumper relocation bolts to raise the
Jedidaddy1
by Cable810 » Wed Nov 18, 2015 8:35 am
Mark is bringing the 3" Body Lifts back
by HawkeyeC25 » Wed Nov 18, 2015 10:26 pm
After careful consideration, I ordered up the 3" suspension lift and I'm going to stick with 32" tires. Seems as though even with a 3" body lift, anything over 33" will still probably require fender trimming. To me, not worth the effort at this point since I don't plan to maximize my offroad capability... yet :)
Thanks so much to everyone for the advice and quick responses!!
HawkeyeC25
