offroadTB.com • View topic - Stuck upper strut mount
by Chango » Tue May 20, 2014 10:56 pm
I've tried all I know. Compressed the spring just fine, top nut came off, now I can't get the mount off the shaft..? Couldn't pry it off, tried to rotate it off, finally I cut the shaft flush with the bushing to try to use a punch. I still can't get this off.
Any help?
Chango
by markmc » Wed May 21, 2014 5:28 am
Well.. The upper mount and strut are now junk..So if it were me, i would heat up the center metal insert that is molded into rubber mount until the rubber separates from insert..
Remove the garbage mount and decompress the spring..
Someone else may have a better idea, but thats what i have done couple times..
Safety Note:
DO NOT ATTEMPT HEATING OF METAL INSERT WITHOUT SPRING COMPRESSORS ON THE SPRINGS..
markmc
Rank: Mall Rated
by Chango » Wed May 21, 2014 6:10 am
Im not trying to save these mounts, after seeing the condition of the bushing.
I've tried heat, that's what caused havoc on that upper bushing first. Maybe not ;enough... I'll prolly just cut the shaft and slide the spring out.
Chango
by Bacnbit » Wed May 21, 2014 8:00 am
Bacnbit
by v7guy » Wed May 21, 2014 11:08 am
the shock shaft is gonna be hard to cut.
I'd just burn out the bushing, at this point it doesn't matter, it'll take 5 minutes.
If you don't want to be bothered I have 89 springs and shocks for sale in the classifieds lol
by Trail X » Wed May 21, 2014 11:45 am
Just take the pressure off the spring, and let the spring shoot the bushing across the room. :twisted:
by Chango » Wed May 21, 2014 12:34 pm
Chango
by navigator » Wed May 21, 2014 12:47 pm
there might be some guys with stockers that can hook you up.
by DirtyBacon04 » Wed May 21, 2014 3:33 pm
Your spring compressor might've cracked because you didn't grease up the threads. Roadie might fine you for such a violation.
I've got POS bilstein shocks in 89s with torn up 2" BDS spacers.... if you're interested. lol
by Chango » Wed May 21, 2014 5:00 pm
Thanks , but I've got some new bilsteins going in.
Used anti seize on the bottom of the threads. Started cracking where the casting marks are. I'm sure I didn't have something going right, or else we'd see lots more of morons breaking compressors. Image
Chango
by ARC- » Thu Sep 04, 2014 12:51 am
I replaced new upper control arm bushings in the front suspension, and when installing Marks 3" new spacer my bolt seemed flush with the top of the spacer and no way to thread the bolt on.
The second issue was the bolts on Marks 3" spacer did not want to go into the spring perch bolt holes on the frame, it seemed the holes were too small.
97x 5.3 LH6 ŘWD
SPRING LIFT ONLY ON 33"
Z71 springs!
ARC-
DriveTrain: AWD
