offroadTB.com • View topic - what shocks for rear with moog 81049 and 2" spacer
by harvyne » Fri May 09, 2014 1:39 am
I have added my markmc 2.5" lift and i put stock replacement coil springs(moog 81049) in rear with the 2" spacer. My rear shocks are banging/thuding now over bumps, ive done alot of research and im narrowed down to the skyjackers or the bds shocks. I know alot of you add the z71 springs for added lift but im certain my springs are stock height for envoy. Which rear shock will bolt on without any mods or adding spacers/washers etc. to the factory mount.
thanks
harvyne
by navigator » Fri May 09, 2014 8:01 am
I think the BDS shocks are the only lift shocks that have our spacers built in.
I think BDS offers a Fox shock as an upgrade, it might have the spacers built in as well. You'll need to check on that.
by TBYODA » Fri May 09, 2014 9:28 am
It not bad adding the washers, really easy and you only need them on the bottom. I used the skyjackers N8030. Check out there web site under scratch and dent. I could not find anything wrong with them.
http://skyjacker.com/product.php?ProdID=30505
by navigator » Fri May 09, 2014 9:33 am
I run the N8030s as well. I think I have 8 washers on each side of each shock or something like that. It's no big deal adding the washers.
by Cable810 » Fri May 09, 2014 9:40 am
I'm running the same skyjacker shocks and I really like them. I have posted in my build how many wahsers and the thickness of the washers I used.
by TBYODA » Fri May 09, 2014 9:47 am
Form his build "20, 7/16" Grade 8 washers to shim the lower half of the shock(where it mounts to the axle)."
by harvyne » Fri May 09, 2014 9:56 am
thanks ill check them both out. if its adding washers to the existing mount holes then sure thats easy i just dont want to have to go drilling new holes or have any welding done.
harvyne
by navigator » Fri May 09, 2014 10:09 am
no holes or welding.
by ErikSS » Fri May 09, 2014 11:04 am
I found a way to pull the bushing out of the original shock. My method was dangerous so I wont post it... haha but you can remove the spacer from the stock shock and use it on the Skyjacker N8030. A press or maybe heat???
by harvyne » Fri May 09, 2014 11:07 am
ordered skyjackers n8030 from amazon, should i not drive or is it safe to drive just dealing with the noise.
harvyne
by v7guy » Sat May 10, 2014 12:36 am
You're likely over extending the shock. So the internals are slamming into the top as it extends. Eventually it'll rip itself apart, might be tomorrow, might be in a couple months. At the point that happens you'll have no shock at all and you'll just be bouncing on the spring. It would be disagreeable.
by HARDTRAILZ » Sat May 10, 2014 11:12 am
My skyjackers show rusting after less than 6 months but function well.
by The Roadie » Sat May 10, 2014 12:56 pm
by harvyne » Sat May 10, 2014 6:46 pm
i replaced my shocks 6 months ago with gabriels and they are all rusted out. the finish on them doesnt last long. i may throw a coat of rustoleum paint on the skyjackers before install.
I drive 7 miles to work on smooth road so that will be the extent of my driving till i get my shocks.
harvyne
