For the fronts, you will notice a trend in the build threads. Most folks are running Bilstiens. If you want to splurge, get the Radflo Coil Overs.
For the rears, there is more diversity, but once again, check the build threads and check the link that TBYODA provided. () I have the Skyjacker 8030s. (~$45 each with Amazon Prime). But instead of a bunch of washers on the bottom shock mount, I picked up a couple nylon spacers at the local hardware store. Been running them for a year with no problems.
The spacers are 1/2" tall with an inside diameter of 1/2". Notice the single washer between the spacer and the shock.
