offroadTB.com • View topic - Leveling out my Envoy?
by Jimmyz » Mon Jul 01, 2013 10:39 pm
I just bought my Envoy XUV with the 5.3L and air ride in the back. Truck has 150k on it. Still running on the stock suspension. I would like to level the truck out.
What's the best way to level it out? I'm going to replace all the shocks too, so if there's a leveling kit with shocks for these trucks please advise me on were to buy one.
I won't be doing any hard core off roading, just want to level it out and improve the ride quality.
2004 GMC Envoy XUV 4x4 5.3L
2003 GMC Yukon XL 2wd "Regency Conversion"
Jimmyz
Vehicle: GMC Envoy XUV
by v7guy » Tue Jul 02, 2013 2:16 am
Maybe a half inch spacer above the front strut. Bilstein HD shocks are the standard suggestion for the front. They work well.
by bilit66 » Tue Jul 02, 2013 10:50 am
You might want to replace all of the coil springs. With that many miles they probably have some sag in them. Just a thought.
06 Denali XL
MarkMC 2 1/2" Suspension Lift, MarkMC 3" Body Lift
Beilstein HD's in the Front, BDS 55619 Lift Kit Shocks in the Rear, 32x11 No Spacers
bilit66
Vehicle: GMC Envoy XL
by The Roadie » Tue Jul 02, 2013 11:47 am
by Jimmyz » Wed Jul 03, 2013 10:01 pm
OK. I ended up buying some Monroe quick struts for the front of my envoy. Can I still install a 1" spacer with these struts? Where can I find a 1" spacer? Seen 2" everywhere but I don't wont to rise the rear of my truck because it has good work factory bags on it now. Don't think you can lift a truck with air bags? Right?
Jimmyz
by Cable810 » Wed Jul 03, 2013 10:17 pm
E-mail MarkMc he can set you straight for the spacer. Yes you can lift with airbags. Roadie installed airbags in his rig and is running, what 2, 2" spacers and Z71s? This is something more suited for GMTNation.com not offroadtb.com hence the name Off-roadTB we wheel our rigs not pussy foot around the mall. Not trying to be harsh in any way just saying.
by The Roadie » Thu Jul 04, 2013 2:20 am
There's a difference between factory Envoy air springs, and Airlift1000 bags inside coil springs. I have the latter. BDS spacer on top, SMAXX on the bottom. Tahoe Z71 springs with the larger Airlift bags needed for those springs.
by HARDTRAILZ » Thu Jul 04, 2013 6:43 am
Some of us wheel them. Others talk about and act tough on here.
Why can't the guy just get help? He shared his mission and made no BS claims yet this site once again gives someone shit about a mall when 90% of the trucks on here never see anymore than a dirt road.
by Jimmyz » Thu Jul 04, 2013 8:27 am
Jimmyz
by v7guy » Thu Jul 04, 2013 8:28 am
by HARDTRAILZ » Thu Jul 04, 2013 8:38 am
Either marks inside or outside spacer but you have to measure your rig to know how much of a bump the front needs.
by Shdwdrgn » Tue Sep 17, 2013 2:43 pm
Shdwdrgn
Contributing Author
by HARDTRAILZ » Tue Sep 17, 2013 3:27 pm
Or just use the existing inside strut spacer he makes n lose the outside...
Not sure he can do custom as easy as he used to...fyi
by Silverbullet » Tue Sep 17, 2013 5:07 pm
Silverbullet
by bilit66 » Tue Sep 17, 2013 10:00 pm
You can run the spacers under the stock rear air springs also to lift it. You asked about lifting with the air ride. I used Marks 2 1/2 level kit. I started with installing the front kit and adjusting the sensors to lift the rear. I then installed the spacers under the rear air springs. I rode like that for 6 months or so. Then sprung a leak in one of the bags. this will happen. I replaced the bags with coils from Arnott. Variable rate with spacers. Very pleased. You have many options. There is a ton of information on this sight. It is full of very knowledgeable people that have posted great information. Search and search. Good Luck
06 Denali XL
bilit66
