offroadTB.com • View topic - Mark's 3" lift spacer.
by Opeth » Mon Jun 17, 2013 8:16 pm
Does anyone know if the 2 mounting bolts are replaceable that pass up through the strut mount? It's been quite a while since I installed mine but am planning on replacing a ton of suspension parts shortly, I noticed tonight that they are pretty rusted over and don't even know if I'll be able to get the nuts off. I " think" they were splined/press fitted and will just replace them with stainless since NY spends more in salt than other helpful things.
by Opeth » Tue Jun 18, 2013 12:58 am
Mark got back to me, for anyone who would like to know....
They are a fully threaded high tensile M10 x 40mm coarse Allen socket bolt, thread in from the rear ( spring) side.
by darring70 » Tue Jun 18, 2013 1:47 am
That is the thing about winter time, I hate salt too, I just had to replace my transmission cooling line because it was all rusty
darring70
by markmc » Wed Jun 19, 2013 3:20 am
markmc
Rank: Mall Rated
by Opeth » Wed Jun 19, 2013 10:27 am
Red or blue lock tite?
by markmc » Wed Jun 19, 2013 2:46 pm
markmc
Rank: Mall Rated
by Opeth » Wed Jun 19, 2013 9:53 pm
Eeek..... Red lock tite and aluminum, so much for an easy task... Lol. Might I suggest a switch to stainless bolts instead of what is currently used Mark?
by navigator » Thu Jun 20, 2013 7:47 am
I was thinking the marine industry doesn't recommend stainless hardware with aluminum boats due to increased corrosion of the aluminum.
after a little digging, it seems to be because of electric fields (water + dis-similar metals) etc which might not have an effect in this situation.
http://en.wikipedia.org/wiki/Galvanic_corrosion
by Opeth » Thu Jun 20, 2013 11:51 pm
It wouldn't have an effect in this situation since its not submerged in water, this is why boats have sacrificial anodes on the out drives which are usually aluminum housings. On a boat they are either zinc or magnesium which are more reactive than aluminum. My out drive has stainless steel bolts on the out drive with no ill effects.
by dvanbramer88 » Tue Jun 25, 2013 12:05 pm
