Extended Control Arms
by mikekey » Sun Mar 10, 2013 12:33 am
Where are you guys getting the extended control arms? I can't seem to make heads or tails searching, other than the Massive adjustable control arms. Yet some of you seem to have had extended control arms before massive started making their product. I saw two mentions of Spohn, but no mention of the actual part. I'm planning on running 305/70/17's very soon in the future, so I'm thinking I'm going to want to extend the rear lower control arms.
by Moots1288 » Sun Mar 10, 2013 12:56 am
A bunch of guys got em custom made.. Me and v7guy are actually going to be building a sets
by djthumper » Sun Mar 10, 2013 3:42 am
There use to be another guy that was making them, he hasn't been around in a while. If I were getting a set now I would get the Massive set.
by mikekey » Sun Mar 10, 2013 9:14 am
Hmm.... Ok I suspected as much. In two threads I saw mention to PM gotricegh.
by Moots1288 » Sun Mar 10, 2013 11:22 am
mikekey wrote:Hmm.... Ok I suspected as much. In two threads I saw mention to PM gotricegh.
Yea I've sent him a pm before also
by The Roadie » Sun Mar 10, 2013 12:40 pm
If you lengthen the lowers, you also need adjustable uppers or else your pinion angle will change and possibly damage the u-joints. Or cause driveshaft vibration.
by mikekey » Sun Mar 10, 2013 8:08 pm
The Roadie wrote:If you lengthen the lowers, you also need adjustable uppers or else your pinion angle will change and possibly damage the u-joints. Or cause driveshaft vibration.
Thanks Roadie. looks like my best option is going to be to plunk down some cash on the Massive set for uppers/lowers to avoid rubbing.
