king shocks?
by MK-voy » Tue Feb 07, 2012 8:09 pm
I came across this shock company that is used by team hummer in the dakar race http://www.kingshocks.com/ any idea about them??
MK-voy
by Trail X » Wed Feb 08, 2012 12:53 pm
Looks like 25001-150 might work. It's application is the Tahoe/Yukon 07+ as an OEM performance replacement.
Remote res is nice, but honestly, I'm not sure I've heard of anyone getting shock fade with the standard gas shocks from BDS/FOX.
You'd just have to shim the bottom with washers, per SOP.
by The Roadie » Wed Feb 08, 2012 5:40 pm
I tried hard to induce shock fade with a few high speed runs over ten miles of desert washboards, and my gas BDS were fine. But to keep from shaking a hundred fasteners loose from the vehicle, I was also aired down, so the high frequency vibrations were mostly being absorbed by the tires and turned into heat there instead of in the shocks. So perhaps the definitive trail that needs remote reservoirs, if there are any and those shocks are functional and not just for the mall, just isn't suitable for the platform. I think they were developed for desert prerunners - high speed trail-explorers who do a lots of jumps and whoopsies. We don't have the suspension travel for that, and we're a bit (like a factor of two) too heavy.
by MK-voy » Thu Feb 09, 2012 5:12 am
Roadie , James i have asked this before can i use the fox shocks that is designed for yukon and thaoe lifted 2 inch with the 25cr skyjacker coil.
MK-voy
by Nakashige » Thu Feb 09, 2012 5:42 am
I am running the SkyJacker Shocks with Marks old 2.5 and Z71 Springs no issues when I have weight in the back. It tops out when I don't have weight in the back
Nakashige
Vendor
by Trail X » Thu Feb 09, 2012 2:56 pm
MK-voy wrote:Roadie , James i have asked this before can i use the fox shocks that is designed for yukon and thaoe lifted 2 inch with the 25cr skyjacker coil.
You might want to contact AlekG, hes the only one I remember that has the skyjacker springs.
He does have a website: http://88xpeditions.blogspot.com/ He might have information there.
by djthumper » Thu Feb 09, 2012 3:02 pm
You might check with Hardtrailz, I think he is on the 25cr coils now as well. IIRC
by MK-voy » Thu Feb 09, 2012 3:30 pm
:salut: ok. Will do so.
MK-voy
