djthumper wrote:If you are buying rims get them with the 4.5" backspace and you won't need the wheel spacers. Unless you want to go with the more universal 6x139 then try to keep a 6" backspace to help keep them tucked in.
chevycrew wrote:Damn, beat me to it.
Spacers, shocks, and maybe the tie-rod end upgrade if you are replacing them anyway.
navigator wrote:you need wheel spacers to run a tire that size.
with Z71s + Mark's lift in the rear you need longer shocks(BDS, SkyJacker etc)
stormsurge wrote:might as well change springs 3/4 lift
JamesDowning wrote:stormsurge wrote:might as well change springs 3/4 lift
What do you mean by "3/4 lift"?
Your original post was written as if you were talking... that doesn't always work on a written board. Be sure to think out your thoughts, and write them clearly. For instance, a post like yours would be great in the future by making use of the...
- list
- code
JamesDowning wrote:Learn your tool...
JamesDowning wrote:Use your units!
fishsticks wrote:JamesDowning wrote:Learn your tool...JamesDowning wrote:Use your units!
What with you these days?
stormsurge wrote:If my code was right it was CC. So i have the #80's on it. eather way i want it a litte stiffer when im on the breaks. If i get a little lift too, cool. If not no matter, im lifting anyway. thanks for asking.
stormsurge wrote:After checking prices this is what i can do for now. Marks 2.5 lift + spacers. New balljoints, upper and lower from proforged. New struts bilstein. New tires {fierce attitude] 265/70/17's and rims. $2415.00.
NC_IslandRunner wrote:stormsurge wrote:After checking prices this is what i can do for now. Marks 2.5 lift + spacers. New balljoints, upper and lower from proforged. New struts bilstein. New tires {fierce attitude] 265/70/17's and rims. $2415.00.
Please tell me the rims aren't blingy...........
