offroadTB.com • View topic - Towing with a body lift
by Rob93 » Thu Jun 30, 2011 3:13 pm
I know there's a thread on the OS but not sure if we have one here. I have Marks 3" body lift and will need to start towing around my Jeep once its finished. Anyone have experience with the brackets holding up? I've been pulled out a couple times by my hitch since the body lift but nothing serious... The cherokee is about 3300 lbs and I dont have a trailer yet but I assume it will weigh in around 2,000 lbs... So a bit over 5k total
Even if I re-gear I'm not sure how 34s are going to do towing the jeep anyways... I might just have to go smaller :(
Rob93
by fishsticks » Thu Jun 30, 2011 3:18 pm
Like everything on my truck, my rear hitch/body lift brackets have been abused. They haven't moved after lots of static and dynamic extractions, and a good dose of towing....usually in the form of a 6x12 enclosed trailer loaded with equipment.
You won't be a race truck... but I tow fine on 35's as long as I keep an eye on trans temps. My rear tires rub pretty good when I do tow though... probably time to take the extra set of control arms I have and make longer ones.
The old Trailblazer -
by Rob93 » Thu Jun 30, 2011 3:23 pm
Rob93
by fishsticks » Thu Jun 30, 2011 3:28 pm
by navigator » Thu Jun 30, 2011 4:23 pm
so with the body lift you can still tow?
I was concerned about getting the BL and still towing my bass boat.
by bartonmd » Thu Jun 30, 2011 5:04 pm
If you're going to tow something heavy like a vehicle on a trailer, I'd ditch the blind bolts in favor of fishing regular grade 8 bolts through...
by rgraboske » Thu Jun 30, 2011 8:29 pm
Mine has 4.10s and stock size tire's, but I pretty regularly tow various cars on an 1,800 lb trailer. With my GTO, tools, spares, and the family loaded up, I'm right at the limit weight-wise, and it tows fine. Power is not a problem at all.
rgraboske
by Rob93 » Fri Jul 01, 2011 3:08 pm
Rob93
by Trail X » Fri Jul 01, 2011 3:14 pm
Are you talking about replacing the nuts too? Without weld nuts it'd be impossible.
Either way, you're probably not going to see any benefit. The clamping load on the bar is what holds it in place, not the shear strength of the bolts. The stock bolts are probably 10.9 anyways.
by Gordinho80 » Fri Jul 01, 2011 3:37 pm
FYI... I just took my rear bar off temporarily and noticed that they are in fact 10.9 bolts.
Mario -
by bartonmd » Fri Jul 01, 2011 3:48 pm
by Trail X » Fri Jul 01, 2011 4:49 pm
Ah, I've never seen a bolt like that before. Pretty slick. But it would seem weld nuts would be a lot cheaper.
Did Kyle weld on nuts? or was he somehow able to fish a wrench into the frame?
by bartonmd » Fri Jul 01, 2011 5:39 pm
