swaybar links
by snioc » Sat Feb 12, 2011 6:35 pm
Im sure this topic is covered already but i just want to make sure. Is there a certain way to replace the links, it looks easy enough, im guessing you just do one at a time? looks like it would take no more then 30 minutes.
work to live...not live to work.
snioc
by The Roadie » Sat Feb 12, 2011 6:54 pm
Doesn't it?
:woot:
The truth is that OEM links often have corroded nuts, and 2-3 days of preparation with PB Blaster sometimes helps. Sometimes, you put the hex wrench in the end of the threaded shaft to get some counter-torque, and the hex recess strips out and them you have to break out a Dremel or air tool with an abrasive cutoff wheel to destroy everything in sight in a fit of alcohol-fueled frustration. :wallbash: :angry whip: :hissyfit:
And then you want to shoot the designers.
:shoot:
It's like the typical home plumbing repair project. It might go so smoothly you want to become a plumber with only one trip to the parts store. Other times it's all weekend and five trips and a lot of spilled blood and cussing. Can't predict ahead of time. :friday:
by Trail X » Sun Feb 13, 2011 6:19 pm
Just cut them off, you don't need the front ones anyways.
by wink » Sun Feb 13, 2011 7:53 pm
The Roadie wrote:the hex recess strips out and them you have to break out a Dremel or air tool with an abrasive cutoff wheel to destroy everything in sight in a fit of alcohol-fueled frustration. :wallbash: :angry whip: :hissyfit:
^^Happened to me.
JamesDowning wrote:Just cut them off, you don't need the front ones anyways.
^^That's what I did, and the rears.
wink ;>
my build
wink
by goulds48 » Wed Feb 23, 2011 8:52 am
The Roadie wrote:Doesn't it?
:woot:
Yep, some Sam Adams and a right angle grinder does the trick quite well, putting the smaxx on are so much nicer to do :cheers:
goulds48
