shocks
by Hpimichael02 » Sun Jan 23, 2011 6:38 pm
when buying shocks whats more important the collapsed length or the extended length ?
and the adjustable bump stops, whats the im[portance of these?
Hpimichael02
by The Roadie » Sun Jan 23, 2011 7:51 pm
Both, but the extended is critical if you don't have limiting straps because that's what stops the axle from extending too far and ripping off your brake lines.
As long as the compressed length lets the bump stops hit first, then the shock never actually gets compressed all they way.
We don't have adjustable bump stops in the rear. I bought some longer Timbrens and never got to putting them in.
by Hpimichael02 » Sun Jan 23, 2011 8:01 pm
I asked about the adjustable ones cause alek has them on his and as curious to see there function but I think they are there to meet the frame stops from over extending if lifted like his ? Correct?
Hpimichael02
by OregTrailBlazin » Mon Jan 24, 2011 2:50 pm
The Roadie wrote: Timbrens and never got to putting them in.
:poke: :happy whip: .. hehe
Johnny Kurz
General Manager
541-474-2879
Wheeler's Off-Road Inc.
Our Vendor Section
OregTrailBlazin
by Hpimichael02 » Mon Jan 24, 2011 5:14 pm
im going with Rancho RS9000XL Pro Series Remote Reservoir ... i can mount the reservoir along the frame or somthing but thats the plan :)
Hpimichael02
by Zero » Mon Jan 24, 2011 6:37 pm
As far as I know, and I have seen AlekG's truck a lot....he does not have adjustable rear bumpstops....instead he uses limiting straps due to his really long dirtlogic shocks, and skyjacker springs.
by Hpimichael02 » Mon Jan 24, 2011 7:01 pm
True I was going off his blog , but that's the setup I'm goin after
Hpimichael02
by Trail X » Tue Jan 25, 2011 5:20 am
Zero wrote:As far as I know, and I have seen AlekG's truck a lot....he does not have adjustable rear bumpstops....instead he uses limiting straps due to his really long dirtlogic shocks, and skyjacker springs.
Bumpstops are for stopping the axle from going too far up... limiting straps are for stopping the axle from going too far down. Its possible that he has both.
by Zero » Tue Jan 25, 2011 10:44 am
:slap: lol thanx JD, I know what bump stops do :raspberry: I only mentioned the limiting straps because as far as I can remember the last time I saw his truck, the bumpstops were stock....however I will stand corrected if someone can chime in otherwise.
by Trail X » Tue Jan 25, 2011 12:15 pm
Zero wrote::slap: lol thanx JD, I know what bump stops do :raspberry: I only mentioned the limiting straps because as far as I can remember the last time I saw his truck, the bumpstops were stock....however I will stand corrected if someone can chime in otherwise.
Gotcha, your wording seemed to imply that limiting straps were an alternative to bump stops.
by Zero » Tue Jan 25, 2011 1:31 pm
me no spreak-a-da ingrish wery well hahahaha.
