offroadTB.com • View topic - Front Shock Dimensions
by Trail X » Tue Aug 10, 2010 10:26 am
Reason: Updated with information from page 2
by fishsticks » Tue Aug 10, 2010 11:32 am
I, err, umm.... have some 88 springs coming with my 4WD parts. :oops:
So I'll have my struts apart soon. I'll get whatever you want.
The old Trailblazer -
by Saxis » Tue Aug 10, 2010 11:42 am
I've got a stock front laying in the carport... Be late tonight or tomorrow before I can get measurements though.
Saxis
by Zero » Tue Aug 10, 2010 2:11 pm
I wont be home till the 16th, but I do have a LCA, Shock, and that dog leg looking lower shock mount in my garage. If no one posts the info u r looking for by then, Ill take a look at it for you.
but what is all this info for? what tricks have u got up ur sleve there JD??????
by Trail X » Tue Aug 10, 2010 2:19 pm
by fishsticks » Tue Aug 10, 2010 2:29 pm
By all means, cry wolf.
I'll guinea pig your idea for you. :)
by Philberto » Tue Aug 10, 2010 2:44 pm
I hope it is a means for more articulation! Lift is nice, but articulation is nicer.
| 2006 Trailblazer LS Desert Camping Edition **SOLD**
by MrSmithsTB » Tue Aug 10, 2010 2:49 pm
It's got to have something to do with using a longer shock in conjunction with the stiffer springs.
Don't you hate when people keep secrets??
by Trail X » Tue Aug 10, 2010 3:10 pm
You guys are on the money. :lurk: :safe:
by johnburgelin » Tue Aug 10, 2010 4:04 pm
Reason: Added image to help ease of thread following
johnburgelin
by Trail X » Tue Aug 10, 2010 4:17 pm
That's essentially what I was looking into... but I hadn't seen pre-made ones before.
Hmph... you're taking all the fun outa this. :lol:
by MrSmithsTB » Tue Aug 10, 2010 4:27 pm
I like being right. I also think this would be a very good way to max out the front suspension without overdoing spacers. Longer shock body + 89s + small spacer = 3"+ lift with better articulation? Maybe so
by Trail X » Tue Aug 10, 2010 4:31 pm
Yep, that's where my mind was at... kinda creating an outside the strut spacer with an inside the strut spacer, which would allow the 89s to sit just right.
by Gordinho80 » Tue Aug 10, 2010 4:37 pm
Now... are our struts 3/8" x 16? I'm about to order me a set!
Mario -
by KE7WOX » Tue Aug 10, 2010 4:42 pm
I have the original shocks (the black Bilsteins), but they're in Prescott, so I can't do anything till I get there on the 23rd
by fishsticks » Tue Aug 10, 2010 4:46 pm
Two concerns:
1. Will lengthening just the shaft of the strut cause the strut to excessively bottom out under compression?
2. Should we be looking at sourcing longer springs to compliment this, instead of stiffer springs with the same uncompressed height?
I believe our struts are a metric thread... 10mm perhaps.
by Regulator1175 » Tue Aug 10, 2010 4:52 pm
Those shock extensions would have made life so much easier when installing the heavier springs on Kyle's truck last week. It was a huge pain in the a** to get them compressed enough to get the upper mounts re-installed.
I have a loose shock, but am 6 hours away from home and wont be back until next week. Let me see if I can get someone to run over there and get the measurements for me though.
by fishsticks » Tue Aug 10, 2010 4:53 pm
One more thought.
The Bilstein HDs have a substantial amount of thread on the shaft. I'd say there's a good 3/4" of extra thread coming out of the tops of mine (from memory). You could add (grade 8) washers to the base of the threads to achieve the same effect as buying an extension. If you believe my measurements then we only have about 7/8" of working room before the CV tripods complain anyway.
by tbangert » Tue Aug 10, 2010 5:01 pm
I understand what you are trying to do, but is this actually safe to do? I mean sure you will be biting quite a few threads, but quality of material used in those extenders would be my main concern.
tbangert
by Philberto » Tue Aug 10, 2010 5:24 pm
I would personally just look into making a mount or finding another aftermarket shock for another application that'd allow us a longer spring/shock assembly. I don't see why you'd mod the assembly when you can just substitute in another shock/spring combo.
