TrailVoy Thread
Gordinho80 wrote:I stupidly ripped the labels off of the springs shortly after getting the truck. I had no idea how useful that information would be now...
johnburgelin wrote:I've got a 2003 TB LTZ and my springs are 6SK and 7SJ, which turn out to be 84 and 83 respectively, what's the reason GM put a lighter spring in one side versus the other? when I replace them should I do the same? like get an 87 and an 86? or just get the same in both sides?
JamesDowning wrote:johnburgelin wrote:I've got a 2003 TB LTZ and my springs are 6SK and 7SJ, which turn out to be 84 and 83 respectively, what's the reason GM put a lighter spring in one side versus the other? when I replace them should I do the same? like get an 87 and an 86? or just get the same in both sides?
As I understand it, GM used a computer measuring device to determine what spring to put at what wheel.
If your particular vehicle had more weight in a particular corner (for whatever reason), the computer would 'up' the spring you have. This was to give proper ride height around the vehicle and to keep it from potentially leaning (which I believe GM had some trouble with in the 90s).
Just replace with the same spring for both sides... the difference is minimal.
johnburgelin wrote:Thanks, I'm thinking about going 87's or 88's depending on how my flipped UCA, UHMW shim, turns out :\
MrSmithsTB wrote:I'm going to be firing in the dark with ordering these, since my front springs are not the original that came with the truck. I'll assume they are the same since they are from an Envoy with 4x4. Based on that assumption they are 84 and 83, 88s should net no more than 1" of lift and if they settle too high I can always take out Marks shim. This should leave a slight amount of rake with the Z71 springs I just installed and safely reach the max limit for the half shafts, effectively allowing for 33s with no body lift and leaving the option of adding a steel front bumper without sagging concerns.
Thank you for this thread
JamesDowning wrote:You can probably identify your stock springs by looking up your RPO codes... that's also covered in this thread.
The springs are off of an Envoy(picked them up when I ditched the lowering kit), and I do not have access to their RPO codes. My stock springs are supposed to be 83 and 84. Since the Envoy was an 04 w/4x4, I am assuming that they are going to be the same. Right now I sit at 8.25 rear and 6.75 front(fender to top of wheel). That's why I want to try not to exceed 1" of wheel lift. It looked like the back was sitting lower than the front, which is why I got the Z71s. Now I have enough rake to play around and make the front higher, but I don't want to end up where I started. The idea behind it is to create enough lift to run 33s without the want for a body lift, so that I can concentrate on upgrading the weak links in the susp system instead of dumping that cash into a body lift. Looks like it between 87s and 88s, based on cost and versatility.
