Finally breaking down and doing a body lift.
by fishsticks » Fri Sep 17, 2010 12:23 pm
Regulator1175 wrote:
You are correct, those are for the 3" body lift.
Nothing a few washers won't fix... :shoot:
by Regulator1175 » Fri Sep 17, 2010 2:38 pm
Exactly! Then when you move up to the three inch blocks down the road you wont have to buy any new hardware!
by MrSmithsTB » Sat Sep 18, 2010 1:59 pm
Getting ready to get to work! Bumpers be gone. Going to run bumperless for a while. Once I get Roadies rear brackets, I can throw the rear cover back on. Undecided as to whether or not to hack up the front impact bar for the sake of a bumper cover. I might leave it so I can have tow hooks until I can get one of Mikes bumpers.
by MrSmithsTB » Mon Sep 20, 2010 6:18 pm
Bam! It's in. I worked out my steering extension issue with some steel epoxy. I did decide to relocate the front bumper. All I need now are the rear brackets and I'm good to go. Here are a couple of half decent images.
by dirty anton » Tue Sep 21, 2010 9:47 pm
looks awsome up there! glad the bolts got good use.
dirty anton
by MrSmithsTB » Tue Sep 21, 2010 9:52 pm
dirty anton wrote:looks awsome up there! glad the bolts got good use.
Thanks! And thanks again for the hookup.
by Trail X » Sat Sep 25, 2010 11:20 am
You used epoxy on your steering extension? Do you feel good about that? Possible loss of steering is a serious issue not to be taken lightly. I just don't want you putting yourself in any unnecessary danger.
by MrSmithsTB » Sat Sep 25, 2010 11:32 am
JamesDowning wrote:You used epoxy on your steering extension? Do you feel good about that? Possible loss of steering is a serious issue not to be taken lightly. I just don't want you putting yourself in any unnecessary danger.
I feel fine with it as a solution until Mark can get one to me. The extension itself is hardened steel. It was a bitch to cut and grind out by hand. It fits mostly tight, but the the shaft is slightly tapered on the inside which gave me just a little bit of movement. Overall it was maybe 1/2" of steering wheel play. Putting the epoxy on the base and sandwiching it all together fixed that. It was just to fix the annoyance, not a safety risk. It's rated at 500 degrees and 5000psi.
by bgwolfpack » Fri Feb 25, 2011 5:17 pm
Are you still running with the epoxy fix or did you change to one of Marks? I'm having the same 1/2" play issue and I'm trying to pin point the issue, granted with no body lift yet only RC suspension.
by Gordinho80 » Fri Feb 25, 2011 5:21 pm
He's not running anything... he took out the body lift.
by bgwolfpack » Fri Feb 25, 2011 5:36 pm
Gordinho80 wrote:He's not running anything... he took out the body lift.
I new that. :wallbash: F^#@!
So does his steering play continue? Kinda hard to ask him if he's no longer around. I may need to start a thread questioning steering wheel play. :coffee:
by Gordinho80 » Fri Feb 25, 2011 5:49 pm
Bot still frequents the site... just hasn't been around for a couple of days.
by MrSmithsTB » Fri Feb 25, 2011 9:48 pm
I've been working my ass off lately, so I haven't had much forum time. Yes it is true that I am no longer running the lifts :( . I ended up purchasing one of Marks extensions. I took care of all of the steering play. If you are having some issues without even having a body lift installed, I would bet that your tie rod ends may be getting to the end of their lives.
by Mooseknuckle » Fri Feb 25, 2011 10:01 pm
Bot miss ya man hope all is going well for you!
I don't dial 911
Mooseknuckle
