EXT Front Brake Swap
by v7guy » Sun Nov 25, 2012 11:15 pm
There's some decent conversation about it here http://forums.trailvoy.com/showthread.php?t=50271
by fishsticks » Fri Nov 30, 2012 1:27 pm
One thing I noticed when I was out on Wednesday. The difference in performance between EXT brakes and regular ones is amplified when the brakes are wet. Also, I heated them up (during some spirited offroad driving) to the point that they stank pretty good, but never experienced fade.
by JCrayton99 » Fri Nov 30, 2012 1:31 pm
After having my beat to hell gouged rotors, the EXT mod is millions times better.
JCrayton99
Rank: Offroad Guide
by nvrs » Thu Mar 27, 2014 3:15 pm
So, Will this upgrade fit a 2003 with 16" stock wheels and spacers? Will I need to grind the caliper?
nvrs
by Moots1288 » Thu Mar 27, 2014 3:50 pm
nvrs wrote:So, Will this upgrade fit a 2003 with 16" stock wheels and spacers? Will I need to grind the caliper?
read.. with the.correct backspacing on 16s youll be alright
by nvrs » Thu Mar 27, 2014 4:09 pm
I did read... , Don't really want to change wheels from the OE. I have the 1.5" spacer from Mark
nvrs
by Moots1288 » Thu Mar 27, 2014 5:24 pm
No youll need aftermarket wheels with 4in backspace or less
by TBYODA » Thu Mar 27, 2014 5:30 pm
nvrs wrote:I did read... , Don't really want to change wheels from the OE. I have the 1.5" spacer from Mark
Nvrs check out this thread it should help more. viewtopic.php?t=4622
by nvrs » Thu Mar 27, 2014 6:01 pm
Ok, So no go till next time I buy tires with NEW wheels...
nvrs
by Moots1288 » Fri Mar 28, 2014 8:26 am
You got it
