Confusion in purchasing a lift kit for trailblazer.
by builtlikearock » Wed Oct 26, 2011 9:48 pm
Thanks everybody. I completally understand now. Best of all I can use the auto shops at school and me and the buddies can work on it for free.
builtlikearock
by navigator » Thu Oct 27, 2011 8:44 am
builtlikearock wrote:....So ill buy that 3 inch body lift.....
I'm not sure the 3 inch body lift is back on the market yet.
Zone also only mentions their 2 inch for the 4.2L and not the v8s.
http://zoneoffroad.com/product?ki=191&gr=-1
I can't recall if anyone with the V8 has done a body lift yet or not. Others will chime in I am sure.
Just thinking about it, I would expect the spacers and bolts are the same and likely the bumper brackets but you might have to adapt/build your own radiator brackets.
You might could be the picture child for the Zone Body lift for the V8 model!
by HARDTRAILZ » Thu Oct 27, 2011 9:39 am
I have installed a 3 in body lift on a v8. Actually used my zone 2 in rad brackets for perfect fit.
It was highvoltages ext.
Rad brackets are super simple and the 3 in ones coul be easily shortened to work.
The 3 in is close to available again. I was just chatting about its return this week
by bartonmd » Thu Oct 27, 2011 9:45 am
HARDTRAILZ wrote:I have installed a 3 in body lift on a v8. Actually used my zone 2 in rad brackets for perfect fit.
IIRC, while I was doing sliders and such at your house, Jeff had me cut and weld the rad brackets in some way, for the V8... I don't remember what, exactly, it was, though...
by HARDTRAILZ » Thu Oct 27, 2011 10:52 am
He was going to have you make some but i thought the 2 inch just ended up working.
by bartonmd » Thu Oct 27, 2011 10:59 am
HARDTRAILZ wrote:He was going to have you make some but i thought the 2 inch just ended up working.
I do remember that he had me cut up the I6 ones, and weld them together in some other fashion... The powder coat stunk when it burned...
by builtlikearock » Thu Oct 27, 2011 11:35 am
I was wondering if markmc still made his lift kits?
builtlikearock
by The Roadie » Thu Oct 27, 2011 11:46 am
Yes. Have you emailed him yet?
by navigator » Thu Oct 27, 2011 12:46 pm
builtlikearock wrote:I was wondering if markmc still made his lift kits?
I think HighVoltage is heading that up now with parts sourced through MarkMC and BartonMD.
It sounds like it is close to being ready to market again.
by HARDTRAILZ » Thu Oct 27, 2011 1:05 pm
Mark still has two suspension lifts but the body lift is being worked on by jeff.
by builtlikearock » Thu Oct 27, 2011 6:39 pm
So, there might be a new plan. The trailblazer my dad has has over 215K on it and im not going to invest in it. Ive been contacting people about different ones. Defiantly with the I6. So mark mc no longer has the body lift? and does he have the z71 springs and shocks for the rear?
builtlikearock
by The Roadie » Thu Oct 27, 2011 7:11 pm
builtlikearock wrote:...does he have the z71 springs and shocks for the rear?
Mark isn't the spring vendor. They're sold on Ebay by suspension modification shops who remove them from Tahoes mostly. Search Ebay for the part number 15234633 or 25978750, or for the description.
by navigator » Thu Oct 27, 2011 8:46 pm
Mark only provides the suspension lift and the wheel spacers.
As Roadie mentioned the Z71 springs are on ebay.
The shocks are usually sourced online.
by Gordinho80 » Thu Oct 27, 2011 11:12 pm
Dude.. Start searching and reading. I'm surprised you've been spoon fed as much as you already have...
by djthumper » Fri Oct 28, 2011 3:18 am
I think we need to have a stickie with required reading links in it.
by The Roadie » Fri Oct 28, 2011 9:31 am
http://forums.trailvoy.com/showthread.php?t=77125
Didn't we have a copy of that list over here? :?
by navigator » Fri Oct 28, 2011 9:38 am
I thought so, Mark's lift needs to be updated on that thread.
by The Roadie » Fri Oct 28, 2011 9:45 am
I can edit anything. Just PM me some details. Mark - you reading this?
by bdp1978 » Fri Oct 28, 2011 11:00 am
The Roadie wrote: Mark - you reading this?
Has he even been on in the past 6 months?
bdp1978
by navigator » Fri Oct 28, 2011 11:46 am
he was last here on 10/26.
memberlist.php
