Busted Rough Country 2" spacer.
by MrSmithsTB » Sat Jul 30, 2011 5:50 pm
navigator wrote:those of us running the 2 inch spacer from rough country, can we put the top spacer from Mark on top of that or one similar or does his top spacer only work with his old lift?
You need to change out the upper mounting bolts for longer ones, I think. Other than that, its plug n play. Only recalling from memory, as I have marks kit.
by navigator » Sat Jul 30, 2011 6:24 pm
thanks Bob, that is kind of what I was thinking.
I think I have the longest bolt that will fit without some modifications of some sort.
I might be able to come in from the top as well but it is just a thought.
I would have to look again but I think there is another 1/2 inch in there. I bought some lock nuts but I ended up keeping the kept the factory nuts and they are longer too.
by fishsticks » Sun Jul 31, 2011 11:39 am
I've run longer bolts in from the top without issue.
by DmccartneyFF2TB » Sun Jul 31, 2011 9:31 pm
Id have to say so Donny i wasnt even wheeling hard at all...... its ok tho i just welded it and i still have the other set they sent me so it is what it is.
Dame
BDS,ROUGH COUNTRY,
Smitty Build XR-C8 Winch
www.wm4x4.com
DmccartneyFF2TB
