by fishsticks » Wed Mar 23, 2011 2:21 pm
Check the resting height again now that the suspension has settled.
Also, you could be lighter in the front end than some of us, and getting more resting lift from 87 springs. That could explain why you were so close to topping out.
You also need to jack the front end up, let the wheels hangs and spin each one. Check for bind in the CV tripods. I have a -little- and haven't had a problem. If they are clunky to move you need to pull a couple washers out... unless you like replacing half shafts.
The old Trailblazer -
Build
