z71+2" spacers
by fishsticks » Wed Aug 25, 2010 3:35 am
irishboy02 wrote:Admittedly im 1/4 irish, 1/4 scotish and 1/2 italian - imagine that, an italian from jersey :finger:
Having a big chunk of Irish blood myself, I can understand why you would claim that heritage over the others. :finger:
by Saxis » Wed Aug 25, 2010 12:09 pm
I have BDS spacers + Z71, so the spacer is on top. I did mine just like the BDS instructions. Unbolted the sway bar, control arms and shocks. Put the frame on jack stands and lowered the rear end enough to get everything out and made sure no lines were stretched too much. Locked the spacers in place, but there was about an inch too little room. I ended up just laying directly under the spring perch and literally bench pressing them into place. I could squeeze them just enough.
Oh, and my name is Murphy. I think I qualify as Irish also....
Saxis
by glfredrick » Wed Aug 25, 2010 12:18 pm
I knew of a dude named Murphy... He had this pessimistic view that anything that could go wrong, would, and at the worst possible moment.
I knew another dude named O'Toole, who said that Murphy was an optimist... Wonder what sort of day he was having. :lol:
glfredrick
Contributing Author
by johnburgelin » Wed Aug 25, 2010 6:26 pm
I just installed the .75" rough country spacer on top of the z71 and 2" mark spacer, I ended up having a couple buddies stand on the bumper while i wrapped a bunch of bailing wire around the springs........ended up letting me lower the axle down enough (after disconnecting the shocks, sway bar, and brakes) to slide the spacer and springs in without having to compress or force anything.
johnburgelin
by Zero » Wed Aug 25, 2010 8:06 pm
Your def gona need some longer BDS shocks.
by johnburgelin » Wed Aug 25, 2010 9:43 pm
Zero wrote:Your def gona need some longer BDS shocks.
Me? I'm thinking about fabbing up some shock extensions for the upper mounts.
johnburgelin
by Zero » Wed Aug 25, 2010 10:22 pm
Wont a shock extension only give you more droop, but less articulation upwards ?
by irishboy02 » Thu Aug 26, 2010 11:33 am
Zero wrote:Wont a shock extension only give you more droop, but less articulation upwards ?
+1
Also need to realize and compensate for the new much higher spring rate. With your shocks now, your going to have about 1/2" of downward travel. To compress youl be fine, but then your rear will SLAM back down. I also had someone tell me that while i was taking a bend slightely faster than i was should have ( i have my reasons ) that one tire was off the ground. I thought he was lieing but what actually happened is as the body rolled, my rear axle was limited to how far it could travel downward, but had room to compress. As the bend went to the right, axle compressed driverside and lifted off on pass side. Just something else to think about. And that was only doing 50
2003 GMC Sierra z71
7" FTS lift
irishboy02
by johnburgelin » Fri Aug 27, 2010 7:51 pm
+1
I've definitely got more than an inch down of travel, It's at least several inches (I have BDS's right now)
and the shock extension might limit some of my upwards articulation (but so will the tire running into the wheel well..... and will definitely add to my droop.
johnburgelin
by irishboy02 » Fri Aug 27, 2010 7:54 pm
Oh, okay then. Thought you were saying that you still had you OEM shocks installed..
Mah-bad
2003 GMC Sierra z71
7" FTS lift
irishboy02
by johnburgelin » Sat Aug 28, 2010 12:06 pm
irishboy02 wrote:Oh, okay then. Thought you were saying that you still had you OEM shocks installed..
Mah-bad
Oh god no.....I could only imagine how bad my life would be if I still had stock shocks/struts.....lol
johnburgelin
by irishboy02 » Sat Aug 28, 2010 4:16 pm
johnburgelin wrote:Oh god no.....I could only imagine how bad my life would be if I still had stock shocks/struts.....lol
Thats why i was a little worried haha
2003 GMC Sierra z71
7" FTS lift
irishboy02
