Fixing my steering today...
by Moots1288 » Wed Sep 25, 2013 8:42 pm
mikekey wrote:Who needs to justify it. Give in to your irrational desires! You know you want to. :) hehe
I know!!! I was reading a bunch that Fab techs wear pre maturely.. Rare parts are the way to go I read in the diesel world.. They're nice and expensive though.
by fishsticks » Fri Sep 27, 2013 1:49 am
So....who's going to be the first to shatter a steering rack? :mrgreen:
by v7guy » Fri Sep 27, 2013 2:50 am
fishsticks wrote:So....who's going to be the first to shatter a steering rack? :mrgreen:
Maybe me, or Matt if he keeps going airborne. LOL
by Moots1288 » Fri Sep 27, 2013 10:47 am
Yea I'd imagine one of us will lol, probably goin to throw some jam nuts on the threads of the tie rods for now.. Donny's idea seems the easiest and cheapest to do.. I like I like
by mikekey » Fri Sep 27, 2013 1:07 pm
I'm thinking of pulling the trigger on those Poly's or the Fab Tech here soon.
by Moots1288 » Fri Sep 27, 2013 1:10 pm
mikekey wrote:I'm thinking of pulling the trigger on those Poly's or the Fab Tech here soon.
Those polys are a good bit of money. If I need em I'd pull the trigger but I got other mods that are higher up in priority. Just do a little bit more research on those fab techs if you haven't already I saw a bunch of threads on silverado forums that the fab techs wear pre maturely.
by ErikSS » Fri Sep 27, 2013 1:27 pm
I like the rare parts TREs. But I'm going Moog based on need and value. $167 a set on Ebay and then use jam nuts on the threads....
by mikekey » Fri Sep 27, 2013 2:03 pm
I meant the Rare Parts, but got them backwards when I was typing it up.
There are some completely unnecessary mods I want to do, so I'm just buying things up. Like, I want to powder coat my next set of CV's. I like the idea of overly heavy duty TRE's I won't have to worry about. That should last us just like the OEM's did in stock mode.
by Moots1288 » Fri Sep 27, 2013 2:12 pm
mikekey wrote:I meant the Rare Parts, but got them backwards when I was typing it up.
The rare parts tres are what a lot of guys were leaning too so I think on out trucks they should be fine as long as you aren't going to any tractor pulls anytime soon.
by mikekey » Fri Sep 27, 2013 3:41 pm
Yeah I just need to check measurements.
by blazinlow89 » Mon Dec 09, 2013 12:54 am
mikekey wrote:Yeah I just need to check measurements.
Did you ever check the measurements?
blazinlow89
by mikekey » Mon Dec 09, 2013 8:33 am
Indeed I did and I bought the Fabtechs.
by blazinlow89 » Mon Dec 09, 2013 8:45 am
Good to know, might be one of my next mods. I also assume they have more adjustment range than the OEM ones?
blazinlow89
by mikekey » Mon Dec 09, 2013 9:44 am
Yes, a matter of fact, I'll post a picture later today.
Originally I saved all 3 of the TRE's in ebay and then forgot to recheck this thread about the Fabtechs. I had Fabtech on the brain from AlekG's post about the dirt logic shocks. Anyhow, I ended up ordering them.
But going back and looking at these compared to the Rareparts, I'd be slightly concerned that the Rareparts TRE's don't adjust enough for our vehicle since they are for the Silverado. I'm not sure if the distance from the inner on the rack and pinion to the outter is longer on the Silverado, but it is an assumption.
For me the outters slid right in place. No need to use a taper like Fishsticks had to in the beginning of this thread. I have a stock inner/outter and the threads on the Fabtech inner match. So hopefully when I get back to round two of trying this I can get the whole damn things on and report.
Based on your build thread on GMT you might just want to save yourself the money and get the regular 2500HD tie rod ends.
by blazinlow89 » Mon Dec 09, 2013 10:17 am
Some things have changed since I started that build thread. Might just spring for the Fabtechs, I want to be once and done. Pricing everything out it may only cost an extra $100 as I have found the Fabtechs for around $250.
blazinlow89
by Moots1288 » Mon Dec 09, 2013 10:19 am
blazinlow89 wrote:Some things have changed since I started that build thread. Might just spring for the Fabtechs, I want to be once and done. Pricing everything out it may only cost an extra $100 as I have found the Fabtechs for around $250.
I have not had a problem with my moog inners or outters if you don't want to sorting for the fabtech
by ErikSS » Sat Dec 28, 2013 11:03 pm
Did I read today that Roadie replaced his due to damage? Does that make him first???
by HARDTRAILZ » Sat Dec 28, 2013 11:18 pm
Moots n Janesys also had to replace theirs earlier.
by ErikSS » Sun Dec 29, 2013 1:50 am
HARDTRAILZ wrote:Moots n Janesys also had to replace theirs earlier.
AJ (hotness) has replaced his too. He was talking about needing another during the summer but it seems his problem turned out to be something else.
by HARDTRAILZ » Sun Dec 29, 2013 3:11 pm
Mine leaks, but I just keep throwing fluid in it since it is not the DD anymore.
