only one day off, bummer if so.Opeth wrote: So weather permitting hopefully Monday on my day off ill get most of this done.
just take a shit load and make your own thread.Opeth wrote:Are there any picture requests that haven't been coveted yet?
TangoBravo wrote:Towed several things with the new style and have had no issues yet. My weight was from 1200 on the light end to 4200 on the heavier end. The 1200 load I do about twice a week. However your concerns have me concerned, with me towing as often as I do I am unsure if I should feel good not seeing any issues or worried that a issue just hasn't showed up yet. One thing for sure I know Mark will get figured out one way or another.
ErikSS wrote:TangoBravo wrote:Towed several things with the new style and have had no issues yet. My weight was from 1200 on the light end to 4200 on the heavier end. The 1200 load I do about twice a week. However your concerns have me concerned, with me towing as often as I do I am unsure if I should feel good not seeing any issues or worried that a issue just hasn't showed up yet. One thing for sure I know Mark will get figured out one way or another.
I'm pretty sure if you tow regularly without issues, then you don't have issues! I would check my bolts from time to time... between the frame and the brackets.
HARDTRAILZ wrote:You did cause alarm...was it so hard to just give the full story? We are all adults. The veiled secrecy seems childish.
Hopefully this is just due to your setup, it does appear that way with no one else reporting anything for years, and you can find a way to alleviate your issue.
Opeth wrote:HARDTRAILZ wrote:You did cause alarm...was it so hard to just give the full story? We are all adults. The veiled secrecy seems childish.
Mark got back to me, the holes are drilled to 3/4" but bolts are 5/8" so there is some potential for slop. I am going to try 3/4" bolts first to see if that fixes this.
It wasn't meant to be a secrecy, I didn't see a need to say something till it was discussed with Mark since nothing major failed and only a minor issue. Adults yes, but no need to cause panic which is what I wanted to avoid. Perhaps I should have worded a thing or 2 differently, my apologies there.
If my bumper ripped off and boat ended up in a ditch, well I would have first come out and stated that.
