Everything needed to rebuild the front end
by rgraboske » Sun Jun 20, 2010 6:35 pm
Upper and lower control arms, new springs, new shocks, ball joints, and axles. The only thing else I could do is replace the inner and outer tie rods, which I will be doing before too long, but need a break from buying parts for a while :mechanic:
(163.36 KiB) Downloaded 124 times
rgraboske
by fishsticks » Sun Jun 20, 2010 6:39 pm
Makes me want to turn a wrench. :thumleft:
by The Roadie » Sun Jun 20, 2010 7:03 pm
Looks like a good start to a trail spares kit as well. :excited:
by KE7WOX » Sun Jun 20, 2010 7:38 pm
How much did you pay for all of that?
KE7WOX
by gotspeed1 » Sun Jun 20, 2010 8:33 pm
You've got it right, if you're gonna do one part, you may as well do it all while you've got it apart. Have fun! :mechanic:
gotspeed1
by rgraboske » Sun Jun 20, 2010 9:45 pm
That's what happened. The lower strut mount on the right side was bad, and the upper left control arm was loose. Everything up front is original, so I decided just to do it right.
I have the whole list at work, but I'll try to go from memory and rounding. I bought the Bilstiens from Shockwarehouse, and everything else from Rock Auto using the 5% discount.
Struts: $120
LCA: $305
Axles: $100
UCA: $80
Upper Ball Joints: $75
Coil Springs: $75
With my other cars I've learned to never add up the total when modifying something :lol:
That's the plan Roadie. I have a corner in the garage where I can keep everything. Now I just need the time to actually do it :happy whip:
rgraboske
