Thoughts on these used tires
by NHARINTON » Sat Jan 30, 2010 12:38 am
So I am all stock for a few months. I do very mild trails alot in the spring and summer and hit silver lake (small sand dunes) every once in a while. Just need a good DD that can do good on trails when needed. Good tires will come when the lift does. I don't want to spend $600 on tires when I will need bigger better tires with the lift in 1-2 mths......
Seems like a great deal. Just wanted to make sure no one had any very bad opinions on theme! Thanks!
http://grandrapids.craigslist.org/pts/1570044433.html
"The accumulation of all powers, in the same hands, whether of one, or many, and whether hereditary, self-appointed, or elective, may justly be pronounced the very definition of tyranny” - James Madision The Federalist Papers #47
NHARINTON
by Zero » Sat Jan 30, 2010 9:51 am
They should be fine. You wont be able to tell how worn they are till you see them though. SO dont commit until you get out there and get a visual.
by irishboy02 » Mon Feb 01, 2010 4:08 pm
Get your tires first. Then plan your build around that. Nothing worse than dropping $600+ prior to lift, only to lift and then not like the look/feel. Tires will be the biggest decision you make out of it all. Choose wisely and make it right the first time.
Keep us posted :coffee2:
2003 GMC Sierra z71
7" FTS lift
irishboy02
