Here are the pictures with the words to follow:
I dont have much to add to the pictures, I just joined the forum tonight.
I know how much more pictures can say sometimes than even a dozen pages of posts.
So what I have here is a completely stock 03 Trailblazer EXT. I purchased the 22" wheels only because a guy was selling them for $275 and I needed new tires on the stock wheels anyway. So the tires in the picture are 285/45 22. Thats 32.1" Diameter x 11.22" Wide. These are mounted on Helo 22x9.5 wheels. I didnt measure the backspacing when I had the wheel off.
Well I had done quite a bit of reading about the upper ball joint and what not involved with that so I ordered the (4) Nexen tires and (4) 1.5" wheel spacers. Well, to leave the tire shop they wouldn't touch the spacers so I drove the truck home with the rear 22's on with no spacers and the factory fronts. So with the front 22's installed with the spacers and the rears without spacers......we have the pictures above. I am aware that it looks dumb! But that's just when I took the Pictures.
NOW......I did take a tape measure and gauged the distance from the sidewall to the upper ball joint mount and i measure 1 1/8" gap.
Im thinking I have two options here:
1. Get rid of the (4) 1.5" spacers and buy either (2 for each side) 1/4" spacers or (1) 3/8" spacer and do slight grinding of the upper control arm around the ball joint. Not much though.
2. Put the spacers on the rear also and install the MarkMC 2.5 lift level.
Im very concerned about premature wheel bearing wear and the extra load on the steering rack with the spacers on and premature cv joint wear with the strut lift.
As far as rubbing goes right now. Still sitting on the factory springs with no lift and 1.5" wheel spacers; I get rubbing only at full lock left and full lock right in the very center of the fender well inner liner in front and behind the tire. The tires do not rub on the outsides at all. I believe some either trimming or some custom brackets to pull the fender well liners away will solve all problems. I havent taken this off road yet but I will very soon and will report back. I will also try to snap some good pics of the rubbing areas of concern and the ball joint and uca clearance tomorrow.
