m/t classic lock?
by c bausch » Fri Jan 27, 2012 6:31 pm
Hey guy just looking for a answer im looking at m/t's classic lock rims stock rim is a 16x7 they have 16x8 and my tires are 285/75r16's I think they will fit but just wanted to make sure (I searched but didn't find my answer) and what psi do you guys run I got a LT's I run them at 50psiwork now that ok?
c bausch
by NC_IslandRunner » Fri Jan 27, 2012 6:35 pm
They should fit fine, I run 40-45psi in mine. Just run what you like and keep and eye out for bad tread wear.
by Gordinho80 » Fri Jan 27, 2012 6:35 pm
You REALLY need to punctuate. I know you're posting from a phone a lot, but you need to put sentences together. Otherwise it looks like a bunch of words and is hard to understand.
c bausch wrote:(I searched but didn't find my answer)
You have to look at the tire's specs. They will list Minimum Width and Maximum Width. Its safe to assume, however, that a tire that fits a 7" wide rim WILL fit an 8" wide rim.
Keep in mind the offset of the wheels, aftermarket wheels may push out further then stock wheels.
by c bausch » Fri Jan 27, 2012 6:49 pm
Sorry for the slow guy text's , when you grow up in camden writing wasn't my strongest point. :facepalm:
c bausch
by djthumper » Fri Jan 27, 2012 7:00 pm
Considering that you are running on Mickey Thompson Wheels, that don't come in our wheel pattern. You are going to be also running wheel spacers which will push you out further. 50psi is probably near the max tire pressure and will give you better mileage, though probably a rougher ride.
by Skindiggers » Sat Jan 28, 2012 12:46 pm
You should have somewhere around 20 psi when off-roading unless you have beadlocks , than you can deflate even more and about 30 psi on road , for a nice comfy ride and max 35 psi on road . I think that 50 psi is to much ..
Skindiggers
by NC_IslandRunner » Sat Jan 28, 2012 1:03 pm
I run about 25psi offroad unless it's sand then I drop down to 15psi won't fall off bead unless you're doin' donuts in the sand.
by MK-voy » Sat Jan 28, 2012 2:00 pm
when u visit any tire sales site they post specification of the tire your interested in but what they post under PSI is the max inflation. on certain vehicle you should find some sticker indicating the best pressure for your driving style and load for example on my benz writen on the back of the gas cap 32psi rear 30psi front if u drive above 80mph 30psi rear 28psi front for under 80mph. other example on my other car they post different psi for 4 or 7 passenger( load u put on the tires) i guess 30 is the best pressure for on road use, and you could go as low as 15 psi off roading if your driving smart. for the rims go with the 16x8 :thumright:
MK-voy
by c bausch » Sat Jan 28, 2012 2:16 pm
Hey guys thanks for all your input . I stopped at my local performance store asking about the classic lock rims when said they might not fit because of the offset and I believe he said there's a 4 inch offset what do you guys think? Would they fit?
c bausch
by The Roadie » Sat Jan 28, 2012 2:21 pm
OEM rims are 7" wide with 6" offset. So 8" wide rims with 4" offset are going to stick out 2" more due to the offset, and 1/2" because of the rim width. Plus 1.5" for the required spacer/adapters. So basically 4" more each side. :o Might look funny or get you a ticket or fling a lot of mud unless you also add Flexi-flares (search for it). And it will make the tire hit the fender opening more in turns because the tire edge is much farther away from the ball joint. But the store is wrong when they said they won't fit. They can be made to fit. You just might not like the appearance if you're not into aggressive offroading performance in which case the appearance doesn't matter.
by djthumper » Sat Jan 28, 2012 2:26 pm
c bausch wrote:Hey guys thanks for all your input . I stopped at my local performance store asking about the classic lock rims when said they might not fit because of the offset and I believe he said there's a 4 inch offset what do you guys think? Would they fit?
Offsets are generally done in mm. Are talking offset or backspace?
by fishsticks » Sat Jan 28, 2012 9:57 pm
Just FYI, running 20PSI off road is a good way to not get any traction. I run the Treadwrights in the TB down to 12 regularly. I've had them to 10... never lost a bead.
I ran the IROKs on my Yota at 5psi today in the snow. No beadlocks.
by The Roadie » Sat Jan 28, 2012 10:11 pm
djthumper wrote:Offsets are generally done in mm. Are talking offset or backspace?
You're right. All the discussion that involves inches was really "backspace."
by c bausch » Sat Jan 28, 2012 10:53 pm
So can someone recommend a simulated beadlock rim for me I have looked everywhere and I just can figure the sizes out with offsets and everything, im looking for a 16x7 or 8 what ever would fit I got a 2.5 lift in the front and going to get a 3body inch body lift in a few weeks , and I prob wanna keep my 33's I want to do a removable ring. I like the steel rims with the bead lock rims on there a little cheaper
c bausch
by fishsticks » Sat Jan 28, 2012 11:14 pm
c bausch wrote:So can someone recommend a simulated beadlock rim for me I have looked everywhere and I just can figure the sizes out with offsets and everything, im looking for a 16x7 or 8 what ever would fit I got a 2.5 lift in the front and going to get a 3body inch body lift in a few weeks , and I prob wanna keep my 33's I want to do a removable ring. I like the steel rims with the bead lock rims on there a little cheaper
You could get a normal steel wheel and have the outer plate of a beadlock welded onto it...
by djthumper » Sat Jan 28, 2012 11:17 pm
Well what you should do then is look at them with 6X5 spacing and run with about a 6" backspace since you will be running a 1.5" wheel adapter/spacer. That should give you plenty of space away from the steering knuckle but not have you sticking too far out of the wheel well and keep the trimming to a minimum.
by DirtyBacon04 » Sun Jan 29, 2012 12:00 am
Here we go with the tire pressure questions again...
by c bausch » Sun Jan 29, 2012 12:30 am
There no tire pressure question again it got answered :finger: but if you would like I can forward all my questions to you? :thumright:
c bausch
by DirtyBacon04 » Sun Jan 29, 2012 12:56 am
You can do that if you have a soft spot for sarcastic-far from the truth-smartass answers...
by c bausch » Sun Jan 29, 2012 1:06 am
Lol im just playing around , I like the steel rim Idea and welding rings, that's probability what ill do
c bausch
